2000 jeep Cherokee sport 4.0 cooling fan won't come on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 2000 jeep Cherokee sport 4.0 cooling fan won't come on
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 05-23-2013, 10:41 AM   #1
MATTHEWOPO
Ac cooling fan won't come on replace relay high pressure switch jumped fan and it does work ac blows cold for a while the blows warm cause fan wont come any ideas
MATTHEWOPO is offline   Reply With Quote Quick reply to this message
Unread 06-12-2013, 08:18 PM   #2
bobbo_xj
Poss you have a bad/loose connection at the relay? When you say jumped fan do you mean you jumped at the relay socket?
2001 XJ Sport, 173k mi.
bobbo_xj is offline   Reply With Quote Quick reply to this message
Unread 06-13-2013, 12:20 PM   #3
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Describe fully under what conditions the e-fan will not come on. Normally the 1999-2001 e-fan only runs when engine temperatures exceed about 218*.
With the engine running, remove the wire plug from the Coolant Temperature Sensor on the thermostat housing. The e-fan should run and the Check Engine Light should come on. If the e-fan runs, the fan, fan relay, and fan are all good.
IF your A/C blows cold then hot, you have an A/C problem.
CJ7-Tim is offline   Reply With Quote Quick reply to this message
