2000 Jeep Cherokee Sport, 4.0, 4wheel - JeepForum.com
post #1 of 3 Old 08-12-2013, 06:19 PM Thread Starter
lulu3669
Jeeps runs fine, and then, say I stop to get gas, go pay, and go to start the car and it won't start. All gadgets still work - radio, wipers, etc., but car is dead when trying to start. This has been going on for almost a year, and sometimes it is worse than others. Didn't happen for two weeks and has happened twice in the past 3 days. It will start after about 10-15 minutes during which time I am turning the ignition, moving the gear shift - automatic -. Someone said Neutral Safety Switch and I saw an earlier post, but it won't start in neutral either. Starter has been replaced as well as battery cables. Help!
lulu3669 is offline
post #2 of 3 Old 08-12-2013, 08:51 PM
ECL
When you say "wont start" I assume it won't even crank. If that's the case, it might still be the NSS. I believe it's contacts need to be closed in either Park or Neutral to allow power to the starter solenoid. If the solenoid doesn't energize, the starter won't work. Carry a volt meter so you can do some diagnostics next time.
ECL is offline
post #3 of 3 Old 08-13-2013, 05:45 AM
Holder350
1995 XJ Cherokee
You can unplug it and jump the contacts for the start circuit.
I would not advise this as a permanent fix, but it would either confirm or eliminate it as a problem.
Driving with the switch unplugged your tranny may act funny and you wont have reverse lights.
Sent from my phone
95' XJ Country - Stock Skids - D30/D35 Limited Slip - 3" Lift - 31x10.50R15 - 4.0 HO - AX15 - NP231
98' XJ Classic - D30/C8.25 - 4.5" RC Lift - 33x12.50R15 - 4.0 HO - AW4 - NP231
Originally Posted by Azzy View Post
You can tell the character of a person in how they treat someone who can do nothing for them.
Holder350 is offline
