2000 Jeep cherokee Bad ECM ? - Page 2 - JeepForum.com
post #16 of 25 Old 06-17-2010, 01:39 PM
JTSTEELE1
Code reader not working
Helpful hint on code readers,I have found in a few instances that if the cigarette lighter fuse is blown you will get nothing from the computer other than a link error message. Always good to ck, also if the ck engine light is not on (other than a blown bulb maybe), you will not get any help from the computer. Hope it helps, J.T.
JTSTEELE1 is offline
post #17 of 25 Old 10-19-2010, 10:47 AM
vtails
I have a 2000 Jeep Grand Cherokee 4.7 that will not crank/start. Initially I was able to get it to crank and start a couple of times by holding the key to the start position for 30 seconds or more but had to do this numerous times to get it to crank and start. The dash "-brake light" stays on as does the "Check Gauges" light and the speedo does not work.I believe the compass and temp gauge also is locked at the last reading and does not change. I removed the ECM to check the connections as well as the fuses and put the ECM back. In doing so I did get it to crank by holding the key to start for 30 seconds 5-6 times but now it will not start. Any suggestions folks? Thank you for any help you cam afford me. The rig is stuck 38 miles up a mountain road without tow truck access.
vtails is offline
post #18 of 25 Old 01-28-2012, 08:57 PM
jrios38
Jeep Grand Cherokee 2000 4.7
My ECM just went bad , I replaced it back in 05 from the dealer 1200 bucks,,ouch... I took it to a repair shop they told me that a circuit was bad..I took off the ECM....Auto computer exchange look \ like there a bunch of scammers according to all the reviews that i saw online...I took of my ECM and I am gonna try to put it back on to see if it does not signals the code p0443 ....I just want it to pass emission I really dont want to spend that much green... maybe your theory works.??? you wont knw if you dont try right
jrios38 is offline
post #19 of 25 Old 01-28-2012, 11:31 PM
filluptrk
When you do that Crank Sensor the bolts on them are stop bolts. You cannot tighten them like regular ones, they will break. Just tighten till they stop, then just a bit more with a small ratchet so you do not have much leverage. Go easy and you should be fine.
filluptrk is offline
post #20 of 25 Old 02-13-2013, 07:14 PM
ATXJeep
In Texas we are required to have a state inspection, before being able to register a automobile. Now, my problem is my JEEP Grand Cherokee, 4.7 liter 2 wheel drive is showing the engine light on. So I have taken to a few different JEEP Shops, and still no dice...
Problem: I have replaced Throttle position sensor, I have replaced solenoid, leak detection pump, and smoked the EVAP system. So there are no leaks, and well the Firestone place said they tested it, and that it is the ECM... Now the deal wants $600.00, and Im thinking junk yard, and replacing it with a used one, SO do I need to reprogram it at that point? is the dealer the only ones that can do that? or is there perhaps something I'm missing here....? Help Please
Keep in mind the jeep runs strong, I drive it daily!
ATXJeep is offline
post #21 of 25 Old 02-13-2013, 08:09 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you have a 4.7 L Grand Cherokee, you should posting questions in the Grand Cherokee section of the Forum.
CJ7-Tim is offline
post #22 of 25 Old 06-06-2013, 10:20 PM
jaydentis
my 1999 jeep cherokee will crank but wont start replaced the fuel pump distributor cap and rotor pickup coil and still wont start any ideas
jaydentis is offline
post #23 of 25 Old 06-07-2013, 11:11 AM
CJ7-Tim
CJ7-Tim's Avatar
Follow the steps in posting #2 above.
CJ7-Tim is offline
post #24 of 25 Old 09-17-2015, 06:30 PM
frEAk081771
i just found a bad ckp. thank you sir. sucks i bought a pcm first.life lesson
frEAk081771 is offline
post #25 of 25 Old 01-05-2017, 04:55 AM
Nordie
read your post and am following. Thanks for the info. Please clarify the CPS ohm reading part for the 2001 4.0. mine read 3.81 on the 1 to 10k scale this indicates a bad sensor correct?
Nordie is offline
2000 jeep cherokee 4.0 ? Redneckbuckeye XJ Cherokee Technical Forum 4 09-29-2009 06:14 AM
2000 Jeep Cherokee Help!!!! LokiCDXX XJ Cherokee Technical Forum 3 12-02-2008 04:24 PM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 11:00 AM
2000 jeep cherokee ceb2367 XJ Cherokee Technical Forum 1 02-25-2007 06:23 AM
2000 Jeep Cherokee (6 cyl) wfoster XJ Cherokee Technical Forum 5 02-11-2004 07:43 PM
