2000 Jeep cherokee Bad ECM ? - JeepForum.com
post #1 of 25 Old 05-05-2008, 10:10 AM Thread Starter
bad455
Hello,
I am new to this forum and getting a 2000 jeep cherokee from my neighbor this evening. She has it a repair shop due to a no start (does turn over ) the repair shop is telling her the ECM computer is shot and it is $1,000 to change it out. When I get the jeep home tonight is there a way to check to see if it really is the ECM ? I do have a odb 2 reader but not sure if that would read a bad ECM. Also I found a few remanufactured ECMS on EBAY reasonable but where is the ECM located on the 2000 cherookes ? yes this is the 1st one I worked on . I always had the older jeeps and never a newer one with computer controlled engine systems . Thank you Bad455
bad455 is offline
post #2 of 25 Old 05-05-2008, 11:08 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The most likely cause of it cranks and cranks but won't start up is the Crankshaft Position Sensor (CPS) located on the transmission bell housing. Often this part is also referred to as the CranKshaft Position Sensor (CKP). CPS/CKP failure is very common. The CPS/CKP can stop working with no warning or symptoms and the engine will not run or the engine may randomly stall for no apparent reason. Typical CPS lifespan is about 150-200,000miles.
Crank Position Sensors can have intermittent “thermal failure”. This means that the CPS/CKP fails when the engine gets hot, but works again when it cools back down.
Symptoms-
- Starter cranks and cranks but engine won't start up
- Fuel gauge and voltage gauges may not work or display properly.
- You sometimes will have NoBus displayed on the odometer after 30-60 seconds.
- A failed CPS/CKP may or may not throw a CEL trouble code.
- Fuel pump should run and prime for 3-5 seconds.
- No spark at the spark plugs.
When the ignition key is first turned ON, 12 volts travels from the ignition switch to the ASD relay. The PCM provides ground to the ASD relay to energize it. The ASD relay sends the 12 volts to the primary side of the coil. If after a few seconds no signal is detected from the faulty CPS, the PCM opens the ASD relay and 12 volts power to the coil and fuel pump is removed.
If the CPS/CKP is failed sometimes the OBD-II code reader cannot make a connection to the computer or cannot read Check Engine Light/MIL codes because the CPS/CKP has failed.
Diagnostic steps to confirm the CPS is the cause of your no-start:
-You should be able to verify a bad cps, by unplugging it, and turning the ignition key to ON. If the voltage gauge and/or the fuel gauge now displays correctly, replace the CPS.
-Unplugging and reconnecting the CPS sensor where it connect to the main harness near the back of the intake manifold usually resets the ECU and if the jeep fires right up after doing this you can bet that the CPS is faulty and needs to be replaced.
-Exchange the fuel pump relay and the ASD relay with one of the other similar ones in the PDC to eliminate these relays as the cause of the no-start. Confirm that the fuel pump runs for 3-5 seconds when you turn the ignition key to ON.
-Eliminate the NSS as a cause of no start. Wiggle the shift lever at the same time you try to start.Put the transmission in Neutral and do the same. Do the reverse lights come on when the shifter is in Reverse?
-Inspect the wires and wire connectors at the O2 sensors on the exhausts pipe. A short circuit from melted insulation or from broken O2 sensor wires can blow a fuse and the ECU/ECM will lose communication.
If you buy a new CPS, get a genuine Jeep CPS. Most auto parts stores sell cheap crappy Chinese "Lifetime Warranty" parts that are poorly manufactured from inferior materials and are often out of specification, or even failed, right out of the box. The ones that aren’t faulty often have a short service life before they fail. Always buy top quality replacement parts and genuine Jeep sensors.Numerous threads detail long and frustrating searches for a "problem" that ended up being cured simply with genuine Jeep repair parts. Buy good quality repair parts and genuine Jeep sensors for best results.
You must also perform basic trouble shooting of the start and charge systems. Remove, clean, and firmly reconnect all the wires and cables to the battery, starter, and alternator.Look for corroded or damaged cables and replace as needed. Do the same for the grounding wires from the battery and engine to the Cherokee's frame/body. Jeeps do not tolerate low voltage or poor grounds and the ECM/ECU will behave oddly until you remedy this.
Crankshaft Position Sensor Connector (CPS/CKP)
CPS Testing
TESTING PROCEDURE 1991 –20014.0L H.O. engines
1. Near the rear of fuel rail, disconnect sensor pigtail harness connector from main wiring harness.
2. Place an ohmmeter acrossterminals B and C or 2 and 3 (See Image). Ohmmeter should be set to the 10K-or-2OK scale for this test.
3. The meter reading should be open (infinite resistance). Replace sensor if a low resistance is indicated.
TESTING PROCEDURE for 1987–1990 4.0 L engines
Test # 1 - Get a volt/ohmmeter and set it to read 0 - 500 ohms. Unplug the CPS and measureacross the CPS connector's A & B leads. Your meter should show a CPSresistance of between 125 - 275 ohms. If the CPS is out of that range by much,replace it.
Test # 2 - You'll need a helper for this one. Set the volt/ohm meter to read 0 - 5 AC volts or the closest AC Volts scale your meter has to this range. Measure across the CPS leads for voltage generated as your helper cranks the engine. ( The engine can't fire up without the CPS connected but watch for moving parts just the same ! ) The meter should show .5 - .8 VAC when cranking. (That's between 1/2 and 1 volt AC.) If it's below .5 vac, replace it.
The 2000 and 2001 will have the CPS in the same location on the bell housing, but the wire connector is on the passenger side, near or on top of the Transfer case, not as shown in the diagram below. Simply follow the wire from the sensor to the wire connector.
CJ7-Tim is offline
post #3 of 25 Old 05-05-2008, 12:04 PM
mhall02
Yep, the CPS on my 2000 failed. Cranked and cranked, no prior warnings, but would not actually fire up, luckily it was in my driveway at home. I could't get a code with my inexpensive code reader so I took a chance since these are known to fail...and was right!! $85 at O'Reilly for a Borg Warner CPS, cheaper than a tow and diagnostic I would guess. Maybe try unplugging and pluggin back in the CPS, some say it will then start and you have narrowed it down to the problem, I did not try this, didn't hear about it till later.
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
Original Owner 308,000 miles
mhall02 is offline
post #4 of 25 Old 05-05-2008, 09:15 PM Thread Starter
bad455
Hi'
I got the jeep home and tried to hook up the odb 2 code reader, It seems like it can not read any codes it comes back with error on the lcd screen. I also checked the reader on my dodge and the code reader is fine. I hope I am right in thinking it is the computer that is what the service station also thought was the problem. The jeep will only turn over but not fire up at all I was thinking about getting a remanufactured computer and swap it out any thoughts ? Thanks in advance Bad455
bad455 is offline
post #5 of 25 Old 05-05-2008, 09:35 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
Another vote for the CPS.
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline
post #6 of 25 Old 05-05-2008, 11:38 PM
crateampscal
according to chrysler, they are only suppose to last 8-10 years. i found a place on the internet called ace.(auto computer exchange). they had one listed for my jeep and it was priced at 249.00. when i called she asked me the price i saw and i told her 199.00.(IM A LIAR) She didnt ask twice sent it out within 3 days. when i got it they sent me a return label. it was really easy and it even has a warranty. something to look into.
crateampscal is offline
post #7 of 25 Old 05-06-2008, 01:18 PM Thread Starter
bad455
hI
Since they were so cheap on EBAY I ordered a new CPS $34.00 and a remanufactured ECM for $199.00 I will replace both and see what happens then repost the results. Thanks for the tips. Bad455
bad455 is offline
post #8 of 25 Old 05-14-2008, 09:55 PM Thread Starter
bad455
New ECm still no good
I replaced the ECM in my 2000 jeep cherokee and It still will not start or pull any codes from the car. I bought a new CPS and will replace it tomorrow. It just makes me wonder why even with a new ECM the code reader comes back ERR just like the 1st one Any ideas ? Also where is the CPS on a 2000 4.0 I thought it was on the bellhousing on the drivers side but I can not se it from under the car. I will also try to check the fuses but I doubt I could be that lucky Thank you Bad455
bad455 is offline
post #9 of 25 Old 05-15-2008, 06:14 AM
x99j
Originally Posted by bad455 View Post
I replaced the ECM in my 2000 jeep cherokee and I still will not start or pull any codes from the car. I bought a new CPS and will replace it tomorrow. It just makes me wonder why even with a new ECM the code reader comes back ERR just like the 1st one Any ideas ? Also where is the CPS on a 2000 4.0 I thought it was on the bellhousing on the drivers side but I can not se it from under the car. I will also try to check the fuses but I doubt I could be that lucky Thank you Bad455
next time start with the cheapest part first (cps). also the cps can sometimes bring down the bus (communication between computer and sensors). so a bad cps can sometimes render the obd2 port useless until the cps is fixed! there are also other canidates that can bring down the bus and cause a no start! but the cps is the most likely culprit. mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #10 of 25 Old 05-15-2008, 10:10 AM Thread Starter
bad455
Thank you Guys
You have been very helpful. as soon as I get home tonight I am crossing my fingers and changing the CPS and will let you know. Is the CPS up high on the bell housing left side on the 4.0 ? and the plug is on the right side ? The Chiltons show it low on the bell housing and plug on the left and I think that is wrong. Bad455
bad455 is offline
post #11 of 25 Old 05-16-2008, 05:36 PM Thread Starter
bad455
Hi
I found the CPS on the 2000 jeep but it is all the way up high on the 4.0 motor. Any hints on getting to it sure is pretty tight in there
bad455 is offline
post #12 of 25 Old 05-16-2008, 05:48 PM
CJ7-Tim
CJ7-Tim's Avatar
Hi
1997-2001 it is at the top of the bell housing and slightly to the drivers side. I gather up all the socket wrench extensions I can find and then put a wobble adapter on the very end. About 2 -2.5 ft long works well. Lay down under the Cherokee and put your ratchet wrench near the transfer case.
DO NOT drop the bolts into the bell housing.
CJ7-Tim is offline
post #13 of 25 Old 05-16-2008, 06:36 PM
nickh007
wow, you are really going about this all wrong lol. you really should have brought it home first and diagnosed it before throwing parts at it. also, not all code readers will work with all vehicles, even if they are from the same manufacturer. the only scan tools i trust with chrysler products are the DRBIII and starscan, lucky me i own a jeep and work at a dealer.
ΜΟΛΩΝ ΛΑΒΕ
nickh007 is offline
post #14 of 25 Old 06-07-2008, 05:48 PM
Niminium
Got the web address for this company?
I've found some called autoecm.com, ecmtogo.com, etc. They all seem to be owned by some mysterious Canadian companies, all routed through the same Arizona internet provider that covers up the actual company information. (No contacts, or physical address, etc.)
I've had such bad luck with Canadian company scams, (Euro-Pro, Shark...) that I just won't do business with them again.
Niminium is offline
post #15 of 25 Old 05-25-2010, 04:12 PM
ghira
I had a ECM problem. The car would run fine then shut down completely in the middle of the road without warning. It was difficult to turn back on. Waited 30 mins then it may turn back on. At first I thought it was the fuel pump. Replaced it then same problem. Thought fuel pump was defective so I replaced another one. $$$.ouch... Then I thought it was crank sensor so I replaced that. Did the same problem. I wanted to go to junk yard to get a ECM because I was 100% it was the computer/electronics. I could not find any and when I put the same ECM/computer back the Jeep 1999 Limited V8 did not shut off on me anymore. It is fine now, no ECM replacement just take ECM out put back in and loosen screws. You should just take out the ECM computer for a day. Put it back and don't tighten the ECM too much it is causing a short circuit somewhere (read it online somewhere). See if that works because Jeep's factory tightens the screws to much causing people to replace the whole thing.
ghira is offline
2000 jeep cherokee 4.0 ? Redneckbuckeye XJ Cherokee Technical Forum 4 09-29-2009 06:14 AM
2000 Jeep Cherokee Help!!!! LokiCDXX XJ Cherokee Technical Forum 3 12-02-2008 04:24 PM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 11:00 AM
2000 jeep cherokee ceb2367 XJ Cherokee Technical Forum 1 02-25-2007 06:23 AM
2000 Jeep Cherokee (6 cyl) wfoster XJ Cherokee Technical Forum 5 02-11-2004 07:43 PM
