2000 grand cherokee limited drivers seat wobbly? - JeepForum.com
post #1 of 4 Old 07-30-2009, 05:50 PM Thread Starter
aquadude91x
Hi im new to the forum so any help is appreciated
my drivers seat has been wobbly for about 3 months now and squeaks when i brake. but a couple of weeks back i moved my seat up and there was a hex head screw tht said "9.8" with a "M" above it which im guessing is mopar on the floor behind it. I cant seem to find where it goes.... i dont see anything broken so i dont think its the bracket that breaks like everyone else ive read about.
aquadude91x is offline
post #2 of 4 Old 07-31-2009, 06:36 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Broken seat frames are not uncommon. You will have to remove the seat from the Cherokee to determine the cause. Usually a few new welds will solve the problem. In extreme cases, a used seat frame from the junkyard is the only cure.
CJ7-Tim is offline
post #3 of 4 Old 07-31-2009, 06:45 AM
little_Jeep
My 2000 WJ had both a broken track and a broken seat frame. I purchased a new to me track from bone yard for $50.00. When I removed the seat, I pulled cushion back to exposed the broken frame, a couple beads and it is as good or better than new. Remove the seat (4 bolts and a couple wires) to get a good look at what repairs your seat needs.
little_Jeep is offline
post #4 of 4 Old 07-31-2009, 08:05 AM Thread Starter
aquadude91x
thanks guys ill have to check the frame out and see what i have to do and ill most likely end up at my local junkyard like you suggested.
2000 XJ limited power seat switch Mike 91 318ic XJ Cherokee Technical Forum 0 08-18-2009 01:02 PM
need front leather seat 92 cherokee limited austtill XJ Cherokee Technical Forum 6 08-10-2009 01:02 PM
grand Cherokee wheels fit a 1993 Cherokee Limited? Spanishfly XJ Cherokee Technical Forum 9 06-09-2007 07:21 AM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 11:00 AM
2000 jeep cherokee limited nosinjcted XJ Cherokee Technical Forum 2 04-13-2003 10:54 PM
