2000 Cherokee Starting Problems - JeepForum.com
post #1 of 12 Old 02-05-2008, 05:05 PM Thread Starter
Jimingle10
Hi Guys,
New to this forum today.
The specimen - 2000 Jeep Cherokee 4.0L v6
The Problem(s) - I'm Living with my grandparents right now, and for the past week or so, all I wake up to is the winding of a starter. I'm not sure why but it takes them about 4-5 tries to start the truck. When it does start is is very rough and usually stalls, followed by some more starter winding to get it going again. (the starter is fine, im just saying winding because its annoying at 5am lol)
After the 2nd time it starts it will stay running...with a little bit of help from the gas pedal. Once its warmed up everything seems to be fine, starts 1st try. Grandmother has said that it seems to be buring up gas a little quicker than usual.
Problem #2 (may be related)
The truck pulls a check engine code (not sure what the code is but if needed I can go pull it) But its for an engine misfire. I've cleared it and it stays off for about 1-2 weeks then comes back on. It usually comes back on after idling for awhile (while driveway is being snow-blowed, the truck is left on for heat and to melt snow etc)
Any insight on this would be great!
Thanks, - Jim
Jimingle10 is offline
post #2 of 12 Old 02-05-2008, 05:20 PM
Crystalship1
Crystalship1's Avatar
Last tune-up (plugs, wires, dist. cap & button, etc.) ? If it's not had a tune-up in a while, I'd do that first. I'd also run a tank of SeaFoam cleaner through it for good measure. BTW - It's a straight (in-line) six, not a V6. Good Luck!!
"Seems like common sense isn't that common anymore"
And by the way.... "alot" is NOT a word!!!!
1997 Gunmetal Blue XJ Sport - 4.0 L. I6 - 4 Dr. - 4x4 - 1.75" BB
Crystalship1 is offline
post #3 of 12 Old 02-05-2008, 05:21 PM
That1guy
That1guy's Avatar
2007 WK
Welcome.
Well a good place to start is the code. Get us the number so we can see if that can help your problem. Does it only do this in the cold weather?
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #4 of 12 Old 02-05-2008, 05:29 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Hard starting with a rough idle and a tendency to stall without keeping your foot on the gas pedal points to a bad battery. The engine computer is sensitive to low voltage and when the battery is disconnected or the battery itself is weak, the computer will lose the idle settings. After the hard start and stall issues it relearns the idle settings in a few minutes and will run and idle normally.
The battery may have enough power to crank the motor but it probably has one bad cell. Take the battery to a repair shop or parts store and have it load tested. Most parts stores will loan you a code scanner to read the check engine light codes.
CJ7-Tim is offline
post #5 of 12 Old 02-05-2008, 05:38 PM Thread Starter
Jimingle10
Brand New Battery 2 weeks ago, it died on one of the starting attempts so better safe then sorry, it was replaced.
post #6 of 12 Old 02-05-2008, 05:43 PM Thread Starter
Jimingle10
Starting issue - most prominent the past 2 weeks but i guess it has happened before (not nearly as bad..takes about 45 sec - 1min to get the car running)
Engine code - Going to retrieve it right now....but this has been going on for 1year +
the passed 2 weeks havn't been all that cold...nothing irregular
post #7 of 12 Old 02-05-2008, 05:54 PM
CJ7-Tim
CJ7-Tim's Avatar
Remove clean, and fully tighten all the wire connections between the battery, starter, and alternator. Make sure all the ground wire straps are present and have clean and solid connections.
CJ7-Tim is offline
post #8 of 12 Old 02-05-2008, 08:11 PM Thread Starter
Jimingle10
I'm pretty sure all the wires n such are fine. Battery was just replaced, havn't had any power issues.
Grandparents own their own code scanner and they cleared it few days ago...I won't be able to retrieve it for a few days (doesn't come back on for awhile). I will keep you posted on that.
Going to check the battery connections tomorrow. Most likely will replace spark plugs/wires also.
While im doing this miniature tune up...how hard is it to change the fuel filter? If it doesnt require dropping the gas tank I probobly wouldn't mind doing that. Any other easy service goodies?
post #9 of 12 Old 02-05-2008, 08:15 PM
That1guy
That1guy's Avatar
2007 WK
The fuel filter is part of the pump and I dont think you can replace it.
That1guy is offline
post #10 of 12 Old 02-05-2008, 08:30 PM Thread Starter
Jimingle10
scratch that then lol
post #11 of 12 Old 02-05-2008, 10:00 PM
Jeep gal
If all the connections and the ground are good, it might be a check valve problem in the fuel pump.
Try just turning the key on, till you hear the hum of the fuel pump, for a few seconds, then off. Do it several times. Then let it crank. It's like priming the pump. If that seems to help, you need to do a fuel rail pressure test, including bleed down.
Jeep gal is offline
post #12 of 12 Old 02-05-2008, 10:09 PM
winks00XJ
winks00XJ's Avatar
If I had to guess I would say that it needs a new fuel pump. My 2000 did the same thing and I replaced several sensors before narrowing it down to the fuel pump. It was hard to start especially when cold unless you turned the key to on then off and then you start it. The check engine light would come on sometimes and stay on for a while with a missfire code. I finally ran a fuel pressure gauge taped to the windshield for a day and discovered that the fuel pump was the culprit. Hope this helps.
winks00XJ is offline
2000 Cherokee 4.0l starting problems oldcodger XJ Cherokee Technical Forum 3 04-20-2009 08:38 AM
2000 Jeep Cherokee - Trouble Starting garde XJ Cherokee Technical Forum 2 07-08-2008 10:12 PM
2000 Cherokee 4.0L not starting help spinkid XJ Cherokee Technical Forum 15 04-02-2008 03:25 PM
Starting Stopping Problems - 2000 XJ Modfatha XJ Cherokee Technical Forum 7 11-26-2007 09:28 PM
2000 cherokee stalls after starting? gplaser XJ Cherokee Technical Forum 0 11-06-2006 07:18 PM
