2000 cherokee sport fuse diagram - JeepForum.com
post #1 of 11 Old 06-01-2005, 05:03 PM Thread Starter
rbw26
Question 2000 cherokee sport fuse diagram
I cannot locate the fusebox diagram on my jeep. The manual says it's on the back of the fuse panel, but no luck there. None in the manual either. ANyone know where I can find one???
rbw26 is offline
post #2 of 11 Old 06-02-2005, 08:51 AM
jeepplow
I can email you the page from the 2000 FSM if you send me an email with your email address. I can't seem to attach anything to my reply or a private email to you through this forum.
Send me a private email (or post your email here if you want) and I will send the page to you.
Mike
jeepplow is offline
post #3 of 11 Old 06-02-2005, 01:27 PM
1986Comanche
1986 MJ Comanche
There would be a fuse panel layout in the owners manual. Just look in the back of the owners manual under fuse it will say fuse panel and go to the page. It will tell you where every fuse is, what amp they are, and what each of them are for.
1986 Jeep Comanche 4x2, 2.5L I-4 TBI, 4 Speed
Blue Jeep Club Member #123
Easy to be a truck. Hard to be a Jeep.
1986Comanche is offline
post #4 of 11 Old 06-02-2005, 03:20 PM
Osteonis
Osteonis's Avatar
2008 KK Liberty
I'll post a pic if you tell me what page it is on in the FSM
99 XJ Sport
Stock
I6
5spd
Class III Hidden Hitch
235/75/15
Bumper Mounted Fogs
Osteonis is offline
post #5 of 11 Old 06-03-2005, 05:40 AM
jeepplow
It's on page 8W-10-2.
I don't have picture posting privileges yet.
jeepplow is offline
post #6 of 11 Old 09-07-2009, 06:10 PM
petmac
bump up. is that pic still available
petmac is offline
post #7 of 11 Old 09-07-2009, 08:38 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The owners manual for the 2000 is missing the fusebox info.
CJ7-Tim is offline
post #8 of 11 Old 09-07-2009, 09:11 PM
Carves
As is the previous models FSM ....
But the info is there after wading through all the circuit diagrams ...
Hi & Lo beam fuses in the junction box.
I also have that list you posted but it conflicts with the factory info on pages 8W - 50 - 2 and 8W - 50 - 4.
Hi beam is fuses #3 & #16 / Lo beam is fuses #4 & #5 according to my 97-99FSM.
Is that posted list specific to - only the 2000 model ??? or has some one got it wrong in one of the publications ???
Carves is offline
post #9 of 11 Old 12-09-2009, 11:23 PM
GregB_00XJ
CJ7 Tim FTW!
Search is my friend, was looking for this last Friday. I was like, "Ok, owners manual says check panel, and then panel says check manual..."
WTF?
Thanks!!
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #10 of 11 Old 02-11-2016, 07:18 AM
MartinBH
2001 Jeep cherokee sport, having problems intermittent head lights, need some ideas, will start usually after I have driven 45/50 minutes.
MartinBH is offline
post #11 of 11 Old 02-11-2016, 06:06 PM
CJ7-Tim
CJ7-Tim's Avatar
Check the headlight plugs, the wire harness plugs, and the wire harnesses for corrosion and/or damage. Clean and snug the ground connections. Inspect the headlamp switch and its plug for damage or failure. As always, check any fuses or relays that are related.
CJ7-Tim is offline
Fuse box and relay diagram for 2001 Cherokee Sport asolinger XJ Cherokee Technical Forum 16 02-27-2016 02:47 PM
Fuse Diagram for 2000 XJs CHoltje XJ Cherokee Technical Forum 11 12-08-2011 06:15 AM
2000 Cherokee sport interior wiring diagram-needed- for my 86 Comanche Jonny878 XJ Cherokee Technical Forum 1 05-27-2009 09:09 AM
Cherokee Fuse Diagram Brutal8 XJ Cherokee Technical Forum 7 10-16-2007 02:51 PM
I need a 2001 Cherokee Sport Fuse Diagram Jeep4X4 XJ Cherokee Technical Forum 4 07-09-2006 05:43 PM
