2000 Cherokee Oil Pressure - JeepForum.com
post #1 of 9 Old 05-29-2007, 06:18 PM Thread Starter
eyebrowski
I am getting a low oil pressure reading when warm and idling. Where can I tap in to check the oil pressure mechanically? There is a plug on top of the oil filter assembly with a brass fitting, can I tap in here? Does anyone know the thread size? Thank you.
Greg
eyebrowski is offline
post #2 of 9 Old 05-29-2007, 06:19 PM
Dannyboy18
How low? My brother's dips down to around 20-30 when it's fully warmed up and idling. Mine does the same.
1999 Cherokee Sport - Black; 4.0L AW4, NP231 w/ D30 and 8.25C.
RE 3.5" Super Ride w/ full packs (4* shims) + OME shocks + RE SYE w/ Tom Woods CV
Yukon 4.10s
AR Baja Alloy Wheels - 15x8 + Bridgestone Dueler Revo A/Ts - 31x10.50x15
TeraFlex Adj. Trackbar + TeraFlex Quick Disconnects & WARN T-case skid
Dannyboy18 is offline
post #3 of 9 Old 05-29-2007, 06:24 PM
curtjames37
curtjames37's Avatar
ENGINE OIL PRESSURE CHECK
(1) Disconnect connector and remove oil pressure sending unit.
(2) Install Oil Pressure Line and Gauge Tool C-3292 or equivalent. Start engine and record pressure.
The FSM states that a min of 13 psi at 600 rpm and 25-35 psi at 800 rpm is required. The first step listed in diagnosing low pressure is the replacement of the sending unit.
curtjames37 is offline
post #4 of 9 Old 05-29-2007, 06:27 PM Thread Starter
eyebrowski
It reads practically nothing on the oil pressure gauge and the check engine light comes on. There is no noticeable mechanical noise to indicate a problem and I just had the oil pump replaced.
Is the oil pressure sending unit the connector on the filter assembly I am referring to in my first post?
post #5 of 9 Old 05-29-2007, 06:28 PM
curtjames37
Yep. Chances are it just needs replaced. They are kind of notorious for going bad.
post #6 of 9 Old 05-29-2007, 06:46 PM Thread Starter
eyebrowski
Does anyone happen to know the thread size/type on that fitting?
post #7 of 9 Old 05-29-2007, 07:05 PM Thread Starter
eyebrowski
1/8 NPT maybe?
post #8 of 9 Old 05-29-2007, 08:08 PM
severous01
severous01's Avatar
1/8 NPT maybe?
no, it's a special socket designed for chrystler only sending units. you can use a metric (18 or 19), but it's not a direct fit and if it's on there good you'll round the corners. i had to 'borrow' a special socket for mine....didnt want to come off.
but if you're talking about the metal part that's attached to the metal part that actually screws into the oil filter adapter...that's a standard pipe fitting...NPT, and i'm thinkin maybe 1/4 or 5/16.
severous01 is offline
post #9 of 9 Old 05-29-2007, 08:12 PM
curtjames37
Yeah, I think it is a little bigger than 1/4 so 5/16 might be it. Don't quote me on that though I am just going from memory so it might not be accurate.
I got the sending unit off with a pair of channel locks.
2000 Cherokee Oil Pressure Gauge Ace42782 XJ Cherokee Technical Forum 7 05-30-2013 07:15 PM
2000 cherokee with low oil pressure? WHITEXJ7 XJ Cherokee Technical Forum 6 04-22-2009 10:16 PM
2000 cherokee sport 4.0L oil pressure problems any ideas? soonernort XJ Cherokee Technical Forum 2 03-02-2007 08:07 AM
Will a 2000 grand cherokee cd player work in a 2000 cherokee sport? soonernort XJ Cherokee Technical Forum 1 03-01-2007 11:00 AM
2000 Jeep Cherokee low oil pressure terry d MJ Comanche Technical Forum 5 07-04-2006 01:29 PM
