2000 Cherokee A/C Problem - JeepForum.com
post #1 of 4 Old 05-10-2006, 02:19 PM Thread Starter
JFiorentino
JFiorentino's Avatar
Hello, I'm posting this for a good friend who just bought a 2000 Cherokee. It has about 85k miles on it and is in great shape.
He noticed that when the A/C is first turned on that it blows cold, but that after a while it becomes less cold and eventually is blowing outdoor temperature air.
Has anyone experienced this? It seems like it would always blow hot if the refrigerant was low. I thought maybe a lose belt or the A/C Compressor is going up. The lady that sold it took very good care of the vehicle and had it serviced regularly (I haven't seen it yet, but suspect that the belts are all good and tight).
Thanks in Advance.
John
"When approaching a four-way stop, the vehicle with the largest tires always has the right of way"
2004 TJ, Auto w/ OD, 4.0L, Off-Road 36x13.5 Super Swamper IROK's on MT Classic II Rims, SYE, CV Driveshaft, 4:56 Gears, ARB Locker, 3.5" RE Superflex, 2" Body Lift, JKS Quicker Disco's, 9,000# Winch, Toys-by-Troy step-sliders, The Source OBA. And lots more....
JFiorentino is offline
post #2 of 4 Old 05-10-2006, 04:08 PM
rolltide
had same problem with my 2000 cherokee, when i test drove it worked great, bought it,and would stop working , my compressor was locking down after about 10 min. of super cold air,nothing.dealership replaced and it worked for about 8 months with new compressor.died again - trash in system from old compressor,raised cain with dealer, got new compressor at cost ,and replaced entire rest of a/c system ,and heater core,while im in there, 1100.oo $ and 1 yr later working great , not cheap hope this is not his problem.
rolltide is offline
post #3 of 4 Old 05-25-2006, 06:26 PM Thread Starter
JFiorentino
Hey, now he's getting what appears to be HEAT through his A/C system. I wonder if his temperature control cable fell off? Would the knob feel lose if the cable were to come off? Does the 2000 model even use a cable, or is it more like a Resistor.
John
post #4 of 4 Old 05-25-2006, 06:31 PM
cherokee99spt
I have a 99 and it starts out as ice cold ac and then heat sowly mixes in until its feels normal because its a mix of ac and heat which balance each other out. Sometimes after a long time the ac will kick in full gear and cool things down. Probably not any help but thats what happens with mine.
1999 Jeep Cherokee Sport 4x4 Black
Originally Posted by KMcNaught
If the owner of a Hummer ever threatens to crush your Jeep there is a simple means of escape; just drive off the road.
cherokee99spt is offline
Problem with my 2000 Cherokee Classic SmittysXJ XJ Cherokee Technical Forum 14 10-21-2006 09:04 PM
2000 Cherokee a/c problem showes XJ Cherokee Technical Forum 5 07-05-2006 05:01 PM
2000 Cherokee Cylinder Problem wvbwana XJ Cherokee Technical Forum 2 09-12-2005 02:22 PM
A/C problem on wifes 2000 Cherokee trailboss XJ Cherokee Technical Forum 8 12-09-2004 08:50 PM
2000 Cherokee shaking problem reyesmvp XJ Cherokee Technical Forum 4 10-03-2004 01:43 PM
