2000 Cherokee Air Cabin Filter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 2000 Cherokee Air Cabin Filter
TJ Dana 60 - BOLT IN REARRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge Bushings
Unread 08-05-2009, 09:51 PM   #1
Trombly
Where is it?
I found this: http://atozautolights.com/2000-JEEP-CHEROKEE-8998.html
Thanks
Trombly is offline   Reply With Quote
Unread 08-05-2009, 11:32 PM   #2
reeln77
most likely under the cowl on your hood (the piece between the hood and windshield) on a zj im not sure how to remove it my tj has 7 screws phillips heads imagine that something thats not torx! should be on the passenger side above where the heater box in the dash if you have a funky smell through the vent changing it usually helps alot
reeln77 is offline   Reply With Quote
Unread 08-05-2009, 11:34 PM   #3
jeep-noob
Wow that would be cool to add, I know my 2000 does not have one and the dusty trails need to stay out!
2000 XJ, Sport, 4wd, 100k miles
Gas tank skid, Rusty's x-case skid, tow points
10/3/08 installed RE 4.5 full pack kit, AA SYE, Woods DS
32x11.50 Dunlop AT's, 3.75BS on 15" streetlocks
OME shocks, rear disc brakes
HP D30 swapped in
jeep-noob is offline   Reply With Quote
Unread 08-06-2009, 12:44 AM   #4
srmitchell
Wow, That'd be cool.
I have an xj and it is blue
srmitchell is offline   Reply With Quote
Unread 04-19-2010, 09:34 PM   #5
jeep-noob
Has anyone bought this or the plastic frame that holds the air filter in place?
HP D30 swapped in
Unread 04-20-2010, 07:26 AM   #6
Kevin108
Visit us at TheXJGuys.com
Kevin108's Avatar
The stock CAF is 5013595AB. I had to drop the initial 0 for the search I was using to find it.
TheXJGuys.com | My 00 XJ Build | Hampton Roads Jeep Club | VA 4WD Association
It took me a while, but I finally figured it out: catastrophic failure and
the subsequent repairs is the Jeep thing they're always talking about.
Kevin108 is offline   Reply With Quote
Unread 04-20-2010, 07:58 AM   #7
COLOUXJ
2010 JK Wrangler
I thought there was no stock cabin air filter?
"When i die, bury me with my jeep. Its never been in a hole it can't get out of"
Black Jeep Society
My JEEP helped win a War > Your Honda mows my grass!!
Mechanical Engineers Build weapons Civil Engineers build targets
COLOUXJ is offline   Reply With Quote
Unread 04-20-2010, 08:40 AM   #8
mhall02
Mine does not have one. My minivan does, but not the Jeep.
Patriot Blue
2000 Sport 4X4 4.0 inline six, AW-4 Automatic, stock
230,000 miles and counting
http://i37.photobucket.com/albums/e6...Pics/Jeep1.jpg
mhall02 is offline   Reply With Quote
Unread 04-20-2010, 09:38 AM   #9
Kevin108
Kevin108's Avatar
I looked it up at Mopar Parts Catalog
Unread 04-20-2010, 03:28 PM   #10
filluptrk
Saw an enlarged pic of it on The Parts Bin site. Take off the wiper blades then that cowl piece and it fits on passenger side. I would imagine that if you were someone who suffered from extreme allergies to pollens etc and were inside at work or home most of the day then it is probably worth it. It is $14.95 at parts bin, $8.95 at the site in first post. Not too sure how much it blocks airflow, but for me more trouble than it is worth. I love windows down if it is all possible. Phil
filluptrk is offline   Reply With Quote
