#1 | |
'Bigger Member'
2000
I have a 2000 xj sport 2 door and would like to put a 2-2.5" suspension lift on,but all i seem to find are 3" and above.Does anyone know where the best place to find a 2.5" lift is?thnx
#2 |
Here is a big list of lifts put together by Kyle.
http://www.jeepforum.com/forum/f11/all-read-xj-suspension-kit-options-enjoy-382635-post3394819/ ITs in the FAQ. Any more questions just ask. Oh and what part of WV are you from?
I'm forever grateful to Speedycat and RnEmOvr for their generosity |
#3 |
'Bigger Member'
Princeton...is there any jeep clubs around here?
#4 |
I'm from charleston. I dont know about any clubs down there. Their is a cool website called jeepinwv.com or something like that. That would be a good place to look.
#5 |
'Bigger Member'
I'll check that site out,thanks.
#6 |
Rubicon Express is a common company when people look for a 2" BB, you could also check out Old Man Emu (but they're pricey) or Rusty's Offroad (but they don't seem to have the best reputation). Teraflex makes a BB as well with shackles and spacers.
You could also piece together your own BB with a bastard pack.
North Jersey Jeep Club Trail Rig: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs |
#7 | |
I did the bastard pack, but IMO go for full 2-3" front coils, they're usually under $100 per pair, and give much more flex than a standard spacer lift. Also, it's not hard to save up an extra $40-$60 when you consider you're moving from a hunk of plastic to full steel wound coils.
One S-10 main leaf can net you 3", or two XJ leafs (depending on sag and everything). I have 3" in back (probably will sag though, it's pretty fresh) from the main and second leaf from another pack. Also, from what I've read, a single main leaf from an XJ can bring 2.25~2.5" by itself. With a 2.5" lift, you may not necessarily need new shocks, but if you want appropriate flex offroad, you should get some (I will when I next get $150 dollars). Most of the time, small lifts do not effect driveline angles enough to cause vibrations, but if they do occur, a homebrew (or bought, if you're lazy) TC drop will help. my two (non)cents
http://www.jeepforum.com/forum/f22/86-xj-w-mpi-budget-re-build-757079/ |
#8 |
OME (Old-Man EMU) makes a 2" lift for the Cherokee. Supposed to be a great riding kit but they say it won't clear 31" tires. If you can live with 30" tires, check it out.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
