2000 4.0 XJ distributor swap - JeepForum.com
post #1 of 5 Old 08-18-2016, 10:06 AM Thread Starter
loveknuckles
Basically I have a 00 Cherokee 4.0 new long block. After I swapped motors out it shot me some code. I'm assuming the code is from leaving the battery system unhooked for a week or so. The Jeep was then rear ended and totaled. So now I have a long block that needs a home. My question is this. Can i put a mechanical distributor in it and bypass having to transfer all the wiring to a new home? If so what would I need to rob a distributor out of to get it to work? Btw my thought is to use it in a samurai. Any information that I can get on the 4.0 is always appreciated and thank you for your time in this matter.
loveknuckles is offline
post #2 of 5 Old 08-18-2016, 11:12 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Will the Jeep 4.0L fit in a Sammy ? The answer is yes, a distributor will fit and function in the 2000-01 Jeep 4.0L Cam Sensor hole.
CJ7-Tim is offline
post #3 of 5 Old 08-19-2016, 12:28 AM Thread Starter
loveknuckles
Thank you very much for the information. Will it fit idk? Hopefully it will without much fab work. Either way its going in there if I can get it running.
post #4 of 5 Old 08-20-2016, 12:26 AM
WillJeep22
1991 XJ Cherokee
So I hear and read multiple things: When I'm setting the ignition coil, is it pointing directly at the #1 spot on the distributor cap or a lil bit past it going clockwise?
Sent from my SAMSUNG-SM-G900A using Tapatalk
Where there's a Will, there's a way!
WillJeep22 is offline
post #5 of 5 Old 08-20-2016, 08:09 AM
CCKen
CCKen's Avatar
Why don't you start a new thread for this. This really has nothing to do with the original post.
While you're at it, you can fill in your Jeep info by clicking "My Account" at the top of the page.
CCKen is offline
2000 , 4.0 , cherokee , distributor , xj
