2000 4.0 runs rough at 45 mph - JeepForum.com
post #1 of 6 Old 01-04-2014, 08:39 AM Thread Starter
DiveFlyFun
When I leave home there is a six mile stretch. For some reason my Cherokee runs rough and sometime backfires if I punch it at 45 mpg. Its runs great at all the other speeds/times. Any ideas why I have this problem? Thanks
DiveFlyFun is offline
post #2 of 6 Old 01-04-2014, 09:26 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Test the O2 Sensor and the Coolant Temperature Sensor. Inspect their wire plugs and wire harnesses for damaged and/or chafed insulation.
CJ7-Tim is offline
post #3 of 6 Old 01-04-2014, 10:17 AM Thread Starter
DiveFlyFun
O2 sensors already replace...will check the coolant sensor. Thanks
post #4 of 6 Old 01-04-2014, 04:22 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
*Assuming that you haven't seen a check engine light? If so, must retrieve codes for guidance.
*Good idea to check the coolant temperature sensor
*I would verify fuel pressure with a stone cold engine and see if it is in spec., which is 49 psi, plus or minus 5 psi. I have seen a fuel pump be marginal at initial start up after which pressure stabilizes after engine has run a bit.....
Good luck and keep us updated!
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 6 Old 01-23-2014, 10:39 AM Thread Starter
DiveFlyFun
Replaced the coolant temperature sensor and the problem is gone. I would have never thought of that sensor...thank you very much for your help!!!
post #6 of 6 Old 01-23-2014, 11:06 AM
CJ7-Tim
CJ7-Tim's Avatar
Glad it was a simple fix.
CJ7-Tim is offline
