2000 4.0 Heads question - JeepForum.com
post #1 of 9 Old 02-11-2013, 11:22 AM Thread Starter
LordWilmar
Is there a way to tell, without removing the valve cover, if my 4.0 has the newer, non-cracking head?
Thanks!
LordWilmar is offline
post #2 of 9 Old 02-11-2013, 12:11 PM
AZ Jeff
2014 JK Wrangler
Do a search on this forum and it will show you where you can see the letters "TUPY" cast into the head.
If you have an original engine in your 2000 model year, it won't have these letters.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 9 Old 02-11-2013, 06:57 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Open the oil filler cap on the valve cover. You should be able to see the TUPY inside. You may have to use some fuel injector cleaner to clear away any oil. Note the orientation and distance from the 0331, which can be seen near the valve cover bolt, on the outside edge of the head.
CJ7-Tim is offline
post #4 of 9 Old 02-11-2013, 09:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Ever wonder what TUPY stands for? Is it an acronym?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 9 Old 02-11-2013, 09:20 PM
dmill89
1995 XJ Cherokee
It is the name of the casting company that made the "revised" 0331 heads.
http://www.tupy.com.br/ingles/home/
dmill89 is offline
post #6 of 9 Old 02-11-2013, 09:21 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Outside this country?
post #7 of 9 Old 02-11-2013, 09:28 PM
dmill89
1995 XJ Cherokee
Yes, it's a Brazilian company.
dmill89 is offline
post #8 of 9 Old 02-12-2013, 09:25 PM
dave564
I was going to start a thread about the same thing.
I have a 2000 Cherokee with ZIP for oil pressure, and will be ordering a short block as long as this head checks out.
In my case I think very early on in the trucks life it cracked, wasted the cam bearings and a dealer just swapped the head. (I hope) I am going to run to the local dodge store this weekend and have the service guy punch it in the computer to see.
QUESTION was/is TUPY the only manufacturer that made the replacement head, or is there another out there?
dave564 is offline
post #9 of 9 Old 02-12-2013, 09:52 PM
dmill89
1995 XJ Cherokee
TUPY was the OEM supplier of the "revised" 0331 heads for Jeep, if you pull a used head from a 02+ WJ (Grand Cherokee) or TJ (Wrangler) it will be a TUPY.
There are many other companies out there making replacement heads such as Clearwater Cylinder head if you want a new head.
dmill89 is offline
4.0 head
