$200 and 100,000 miles - JeepForum.com
post #1 of 10 Old 01-06-2008, 11:52 PM Thread Starter
justinwalden
going to the shop and starting with new spark plugs wires and distributor what else should be changed? oil just got changed
justinwalden is offline
post #2 of 10 Old 01-06-2008, 11:54 PM Thread Starter
justinwalden
oh yeah i have $200 to spend
post #3 of 10 Old 01-06-2008, 11:56 PM
taseal
1993 XJ Cherokee
all the oil in your vehicle (transfer case, both axles, tranny, even PS), and all the filters (including tranny filter)
and clutch fan
'93 Cherokee "XJ" Sport - 4.0 HO - 4x4 - AX15 - Chrysler 8.25 - Fun Jeep
'08 Patriot "MK" Limited - 2.4 - 4x2 - CVT II -DD Jeep
taseal is offline
post #4 of 10 Old 01-07-2008, 12:02 AM
murrayman23
1987 XJ Cherokee
GREASE EVERYTHING..ujoints ball joints etc.
"Rusty" 1987 Jeep Cherokee XJ. 4.0L. 4X4. NP242. 3.5" RE superflex kit. RE Twin Tube Shocks. Rancho RS5000 Steering Stabilizer. Cragar soft 8's. 31" BFGoodrich A/T KO. Warrior Products Rock Crawler Bumper. Cobra CB. Firestik Firefly antenna. KC Daylighters.Half Herculined Half Navy blue
murrayman23 is offline
post #5 of 10 Old 01-07-2008, 03:32 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
air fliter, fuel filter too maybe.
1990JEEPXJ is offline
post #6 of 10 Old 01-07-2008, 05:42 AM
Flexin' XJ
Flexin' XJ's Avatar
1995 XJ Cherokee
Unfortunatly to do what you should do will cost way more than $200. If you have it done at a shop.
x2 on everythis said above.
1995 Cherokee 4-Door
4.0 AW4
4.5" RC System
JKS Discos
JKS Adjustable Track Bar
JCR 1-Ton Steering Conversion
Edelbrock Ceramic Header w/full 2.5" exhaust
33x12.50x15 SSRs
Aussie in front, LSD in rear
Death Wobble
Member GLFWDA
Flexin' XJ is offline
post #7 of 10 Old 01-07-2008, 06:12 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
#1. Replace all fluids in vehicle! (start with tranny, t-case, diffs)
#2. Flush and fill cooling system with new coolant. New OEM thermostat too
#3. Distributor cap (think that's what you meant) and rotor
#4. Plugs and wires
#5. Air filter (your fuel filter is on the pump inside the tank and is generally not replaced unless there are symptoms of fuel delivery problems)
#6. Serpentine belt
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #8 of 10 Old 01-07-2008, 11:24 AM
XJK
The Guru of Nothing
XJK's Avatar
forget going to the shop, do it yourself and save the extra money so you can get the WHOLE job done within your budget. trust me it is easy stuff and you may learn something about your jeep while your at it.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #9 of 10 Old 01-07-2008, 02:15 PM
bikedude189
1993 XJ Cherokee
sorry, the fuel filter is tucked up inside the frame right after the gas tank...only the pump and sending unit is in the tank.
'93 4X4
AX-15
NP-231
2" LIFT
BFG A/T'S
bikedude189 is offline
post #10 of 10 Old 01-07-2008, 04:06 PM
tjwalker
tjwalker's Avatar
On a 99 which is what jcwalden has, everything including the fuel filter is inside the gas tank. Earlier models were different. Here's what the Jeep Cherokee 1999 Field Service Manual says...
FUEL DELIVERY SYSTEM
The fuel delivery system consists of:
the fuel pump module containing the electric
fuel pump, fuel filter/fuel pressure regulator, fuel
gauge sending unit (fuel level sensor) and a separate
fuel filter located at bottom of pump module
tjwalker is offline
How many miles? 89XJBEAST XJ/MJ Cherokee Non-Technical Forum 25 02-03-2009 08:18 PM
How many miles are too many for an xj? andrewp17 XJ Cherokee Technical Forum 37 01-16-2009 04:32 PM
How many miles do you have on your 4.0 XJ? Mike94ZLT1 XJ Cherokee Technical Forum 45 01-17-2007 11:51 AM
100,000.0 Miles with pic caspergotaz28 XJ Cherokee Technical Forum 19 05-07-2005 12:24 AM
How many miles on your XJ? Vrrooom XJ Cherokee Technical Forum 89 03-24-2005 02:53 PM
