2 inch lift shocks - JeepForum.com
post #1 of 18 Old 01-12-2008, 02:24 AM Thread Starter
1988XJ
1988 XJ Cherokee
2 inch lift shocks
what kind of shocks should i get for my xj when i get a 2 inch lift, are there any from other cars that i can get the shocks from and put on my jeep with little or no modification from like the JY?
THANKS
mike
1988XJ is offline
post #2 of 18 Old 01-12-2008, 07:08 AM
severous01
severous01's Avatar
bilstein 5100 from autozone. just go to the cashier and ask for shocks...scroll to bottom where bilsteins are and click...have them click for 2-3" lift
severous01 is offline
post #3 of 18 Old 01-12-2008, 05:30 PM Thread Starter
1988XJ
1988 XJ Cherokee
any that i can get from a truck/ car from a JY?
1988XJ is offline
post #4 of 18 Old 01-12-2008, 05:43 PM
dudeinajp
dudeinajp's Avatar
87-95 YJ front
86-92 MJ rear
93-98 ZJ Up Country Front
93-98 ZJ Rear
some F150s
dudeinajp is offline
post #5 of 18 Old 01-12-2008, 05:45 PM
lifted92xj
lifted92xj's Avatar
1992 XJ Cherokee
not sure but shouldnt some of the zj ones work..since the coils are about an 1" bigger the shocks prob are too. if not what about the special cherokee thats like an inch or two higher..like the up-country or something?
big lift, sick tires, awsome accessories, alot of custom work.
my jeep won the war, your honda mows my lawn
lifted92xj is offline
post #6 of 18 Old 01-14-2008, 04:31 PM Thread Starter
1988XJ
1988 XJ Cherokee
so if i get the 2 inch lift u guys think that i will be able to get away with getting grand cherokee front and rear shocks from the JY?
1988XJ is offline
post #7 of 18 Old 01-14-2008, 04:38 PM
toates89
1989 XJ Cherokee
toates89 is offline
post #8 of 18 Old 01-14-2008, 04:39 PM
FlexdXJ
1997 XJ Cherokee
The RE BB comes with shocks. Maybe check in to that. I hear they ride kinda stiff but i will have to get back to you on that when i get mine installed
97 XJ 4.0 AW4 NP231: BB, 31's CB, Surco Rack, , Autopals, Scangauge II, JCR tail light housings, basically Looks like JCR puked on it and some sweet hood pins! :D
FlexdXJ is offline
post #9 of 18 Old 01-15-2008, 11:24 AM
severous01
severous01's Avatar
you people are crazy. shocks control the springs. if you skimp out on the shocks.....you're destroying ride quality. shocks would be the ONE thing i'd spend money on...and i did. if you buy shocks valved for a huge truck then you'll have a super-stiff ride. and, you may destroy the mounting points as well, if the shocks are too stiff.
any way, skimp out on all the parts that need to be quality. hopefully whoever's in the jeep with you has some pepto....they're going to need it with the nausea coming on.
post #10 of 18 Old 01-15-2008, 11:52 AM
sourskittle
I got rough country 2-3'' lift shocks for $140 shipped off egay. Nitro-charged. I really like them
2002 TJ Apex edition with EFI ford 5.0L H.O., NV3550, 33'' Maxxis A/Ts, 5'' lift with custom built rear 4-link, Ford 8.8 LSD 4.10s, HP D30 with spartan locker 4.10s
sourskittle is offline
post #11 of 18 Old 01-15-2008, 01:22 PM
XJ4oh
1997 XJ Cherokee
You dont NEED shocks for a 2" lift. Thats the max you want to go before you replace them though.
Ive been riding on mine since I bought my Jeep and put the budget boost on. Yes, its firmer but it is not bone jarring. If you go crazy with flexing you can over extend them but with just a budget boost chances are you arent going to do that.
Granted the best and most efficient thing to do is to replace them, but if you are broke and cant afford them dont sweat it.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #12 of 18 Old 01-15-2008, 04:38 PM
AlabamaDan
That's what I thought too. I'm thinking about buying some used coils and add a leaf springs for a 2.5 inch lift. I'm hoping I don't need shocks for that.
Alabama Dan
1988 Jeep Cherokee Laredo 4x4
Bone Stock
163,000 miles
AlabamaDan is offline
post #13 of 18 Old 01-15-2008, 06:37 PM
SmrtJustin
SmrtJustin's Avatar
Yeah, the stock shocks should be okay for a while. I would try to limit the amount of time you're flexing out the suspension. The shocks may not last as long as they normally would, but for now they should be okay.
1999 Cherokee Classic
Deep Amethyst
60,000 miles
Mods:
Dynomax Cat-back
OME CS035RA Heavy Load Rear Leafs (~3.25")
RE 1334 Front Spacers (~2.5")
P.O.R.C. HD SYE
30x9.5 General Grabber AT2s
B&M SuperCooler 70255 and Temp Guage
SmrtJustin is offline
post #14 of 18 Old 01-15-2008, 09:49 PM
XJ4oh
1997 XJ Cherokee
People "have" ran 3" with stock shocks. I imagine that would suck. Im comfortable with 2" max and upgrading them after that.
Baja Aux. Lighting.
XJ4oh is offline
post #15 of 18 Old 01-16-2008, 09:41 AM Thread Starter
1988XJ
1988 XJ Cherokee
ok thanks alot guys! i will run my old shocks till i get enough money to get new ones then.
thanks a lot!
mike
1988XJ is offline
Shocks for a homemade 3 inch lift .... Xeonnemesis XJ Cherokee Technical Forum 20 10-08-2011 02:27 PM
what cheap-o shocks to get -3 inch lift Topgun514 XJ Cherokee Technical Forum 9 10-17-2008 05:55 PM
Stock YJ shocks on 5 inch lift XJ HYRYSC XJ Cherokee Technical Forum 7 04-03-2008 09:54 PM
Kyb shocks for 3 inch lift L5vw XJ Cherokee Technical Forum 3 11-04-2007 05:02 PM
I need some VERY cheap shocks for 3 inch lift Motorvated XJ Cherokee Technical Forum 3 07-16-2007 09:24 PM
