2 high - JeepForum.com
post #1 of 11 Old 10-03-2015, 09:56 AM Thread Starter
mcgillba
1990 XJ Cherokee
2 high
Transfer case won't stay in 2 high. I set it up as per the manual. Thought it was the transfer case so I changed it. Same thing. Anybody have the same issue?
mcgillba is offline
post #2 of 11 Old 10-03-2015, 10:00 AM
lsmurphy
What is it doing that it won't stay in 2H?
Check your motor mounts and trans mount.
lsmurphy is offline
post #3 of 11 Old 10-03-2015, 01:38 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's how the factory suggests you shift the transfer case and I've been doing this since these things were new and I worked at the dealership. Quoted from the owner's manual. The suggestions in CAPS are mine.
"To engage, shift the transfer case lever from 2H to 4H while the vehicle is moving at any legal speed". I LET OFF THE GAS, THROW THE LEVER, TAP THE GAS AND LET OFF.
4L position: " To engage, slow the vehicle to 2-3 MPH , shift the transmission to Neutral, then shift the transfer lever to the right and pull firmly rearward to 4L".
TO SHIFT OUT OF 4L, SHIFT THE TRANSMISSION INTO NEUTRAL WITH THE VEHICLE STOPPED, SHIFT THE TRANSFER CASE LEVER TO 2H, THEN THE TRANS TO D IF YOU HAVE AN AUTOMATIC, OR INTO FIRST GEAR WITH A MANUAL, AND CONTINUE ON.
Revised 11/20/2014
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #4 of 11 Old 10-03-2015, 01:39 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Also this, along with checking mounts first.
https://www.youtube.com/watch?v=BHp2hdvZ4oY
post #5 of 11 Old 10-04-2015, 12:10 AM Thread Starter
mcgillba
1990 XJ Cherokee
when driving in 2 hi it will start grinding when I pull the shifter up to 4 wheel drive it's fine. 4 wheel drive works great. Linkage problem?
mcgillba is offline
post #6 of 11 Old 10-04-2015, 08:26 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
One way to find out...
Check the adjustment and condition of the linkage.
Have you checked your motor and trans mounts as suggested?
post #7 of 11 Old 10-10-2015, 08:03 PM Thread Starter
mcgillba
1990 XJ Cherokee
I have replaced the driver side motor mount and the tranny mount is intact. Does this look right it seems to have too much angle?
mcgillba is offline
post #8 of 11 Old 11-26-2015, 09:30 PM Thread Starter
mcgillba
1990 XJ Cherokee
I have now replaced the tranny mount no change still wanting to jump out of 2 wheel drive
mcgillba is offline
post #9 of 11 Old 11-26-2015, 10:24 PM
Timo_90xj
Timo_90xj's Avatar
Your linkage is all messed up. Replace it and you won't have any issues. In bare minimum, start with linkage bushings, but seems to me linkage has been pulled off from the TC side of the bracket so long it is actually bent out of shape.
This is once again a great example of people spending extra money on parts (new junkyard TC where nothing was wrong with the original one) they don't need, only because no proper diagnosing is done to find out the actual issue.
Btw., when you replace motor or tranny mounts on an XJ (or ZJ/TJ), it is highly recommended to replace all three at once. Certainly never replace just one engine mount, always do them both at the same time.
***Under construction***
Timo_90xj is offline
post #10 of 11 Old 11-27-2015, 05:28 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Well stated.
post #11 of 11 Old 10-26-2016, 12:21 PM Thread Starter
mcgillba
1990 XJ Cherokee
Finally found the problem this year in time for hunting. It was the front axle engagement was slipping out. So I pinned it over so I have permanent engagement on the front axle now it works great. Timo is right I should have done a better job of diagnosing the problem that includes taking advise from guys like him with a grain of salt. What threw me off was I still had the noise even with the front drive shaft out and it sounded like it was coming from the transfercase. Just to let everyone know you can fit a whole moose in the back of a Cherokee with the seat down quite easily.(1/4ered up) Thanks to all who tried to help!
mcgillba is offline
