2.5 Liter motor Problems - JeepForum.com
post #1 of 5 Old 09-15-2009, 10:22 AM Thread Starter
jazzman31
2010 JK Wrangler
Ok I have a 1995ish 2.5 liter motor 2WD(not quite sure on the year just yet)
But the lady says the jeep ran fine, then it dropped two cylinders. According to a repair shop. And it ran like crap. I know before she had a problem with the distributor, where it wouldnt crank some days. I found that to be the distributor cap was cracked. But the jeep just recently had a tune up. I dont see any codes, Any causes that you guys can think of, off the top of your heads.
Thanks
jazzman31 is offline
post #2 of 5 Old 09-15-2009, 12:14 PM
5spdChopper
What exactly is the motor doing now?
1999 Jeep Cherokee Sport 4.0L 4x4 AT 4dr
5spdChopper is offline
post #3 of 5 Old 09-15-2009, 01:14 PM Thread Starter
jazzman31
2010 JK Wrangler
Just sputtering and will barely idle.
post #4 of 5 Old 09-15-2009, 01:19 PM
5spdChopper
So, it sounds like replacing the distributor cap/rotor didn't solve the problem.
I'd say check the common sensors...CPS, TPS, MAP?
post #5 of 5 Old 09-15-2009, 01:29 PM
meek61480
1990 XJ Cherokee
i got a parts jeep, 4cyl 2wd, did the same ting. shop said it was a flat spot in the cam. and a crack in the head.
meek61480 is offline
Some Problems after motor rebuild ilikepie XJ Cherokee Technical Forum 5 07-05-2009 06:12 PM
Problems getting motor out. codysown XJ Cherokee Technical Forum 6 06-20-2007 10:27 AM
93 XJ blower motor problems KWIK6 XJ Cherokee Technical Forum 4 06-12-2007 10:01 AM
Motor Mount Problems krAscH n' BurN XJ Cherokee Technical Forum 9 06-22-2006 11:50 PM
Blower motor problems brennanx4 XJ Cherokee Technical Forum 3 02-22-2005 04:17 PM
