2.5 I4 timing chain noise - JeepForum.com
post #1 of 7 Old 11-19-2006, 02:15 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Im looking into buying another XJ. Its a 96 2door 5spd, beautiful condition. Its a 4banger though. It runs nice but has what sounds to me like time chain tensioner noise. Is this a common problem with the 2.5's? What are some other issues with the 2.5's?
Thanks.
RussoGuitar is offline
post #2 of 7 Old 11-19-2006, 03:49 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Bump.......
post #3 of 7 Old 11-19-2006, 04:03 PM
fufanu360
what exactly does this noise sound like?
fufanu360 is offline
post #4 of 7 Old 11-19-2006, 04:08 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Like a soft knock/ratle that turns into a whuring sound as rpm is increased. Its deffienently coming from the timing chain though.
post #5 of 7 Old 11-19-2006, 04:17 PM
anony91xj
Neither the 2.5 nor the 4.0 have a lot of problems like that. If the deal is cheap enough, I'd get it and fix the chain when/if it goes. They're not interference motors, so it's really not that big a deal.
1998 VW GTI 2.0
anony91xj is offline
post #6 of 7 Old 11-19-2006, 04:32 PM
x99j
you are better off asking this question in the yj section, since alot of yj's were produced with this motor and not alot of xj's. i have a 91 yj with the 2.5 the diesel sound you are hearing is normal and is the timing chain tensioner. mine has done ever since i bought it in 1999 with 60,000 on the odo. it does sound like a meat grinder though.
this noise is not in the 4.0l because the 4.0l has a different set up for the chain. mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #7 of 7 Old 11-19-2006, 06:00 PM Thread Starter
RussoGuitar
1989 XJ Cherokee
Thanks guys, its not an annoying sound, cant even hear it inside so i may just wait till i replace the timing chain to look at it. The deal is very good, other wise i prob wouldnt be buyin a 4 banger. Its a truly mint body and interior. 160,000 miles, new waterpump, rad., hoses, new full exhuast. 8.25 rear which im pretty sure may be a 29 spline becuase the build date is december of 96.
Does a 1997 jeep cherokee have a timing belt or timing chain? everhguevara XJ Cherokee Technical Forum 5 08-30-2009 03:00 AM
WHATS THIS NOISE? Timing chain or piston slap? 4.0H.O.XJ XJ Cherokee Technical Forum 4 08-22-2008 09:05 PM
Timing Chain Noise at Cold Start smokeman XJ Cherokee Technical Forum 16 01-24-2008 06:59 PM
will my old '88 timing chain cover fit the dual roller chain for my '94 stroker? BigOrangeXJ XJ Cherokee Technical Forum 4 06-11-2007 03:38 PM
Timing chain or timing belt? '94 Cherokee LPW2 XJ Cherokee Technical Forum 3 05-31-2005 01:11 PM
