1st to 2nd grind only when cold??? - JeepForum.com
post #1 of 10 Old 12-24-2007, 12:42 PM Thread Starter
Mitchell1789
1995 XJ Cherokee
Ok, so first off, what I think is cold is around 40-50 degrees. Only when I haven't driven my jeep for a few hours at least, I go to shift from 1st to 2nd gear and it grinds a little bit going in to second. HOWEVER, I have avoided this grinding by double-clutching 1st to 2nd. Now after about 2 minutes of driving, it shifts perfectly and smoothly as if it was a brand new transmission. When it's warm outside, it doesn't EVER grind any gears... Anybody have any ideas as to what could cause this?
Thanks!
Mitch
Got a clean xj? Want to sell it? PM me if so.
-04 5spd rubi on 35's- gone
-95 5spd XJ on 32's- Gone
Mitchell1789 is offline
post #2 of 10 Old 12-24-2007, 12:51 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
It's pretty common for that to happen. There is a TSB out on it, but I've never read it. IIRC, a lot of people have solved the problem by using a high quality synthetic fluid like Redline.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 10 Old 12-24-2007, 01:21 PM
toates89
1989 XJ Cherokee
anyone know what weight i should use for my 89 5speed
toates89 is offline
post #4 of 10 Old 12-24-2007, 05:37 PM Thread Starter
Mitchell1789
1995 XJ Cherokee
Matt, apologies for being a NOOB but IIRC? TSB? Is a tsb like a synchro?
~Mitch
post #5 of 10 Old 12-24-2007, 05:48 PM
Timo_90xj
Timo_90xj's Avatar
IIRC = if I remember correctly
TSB = technical service bulletin (or something like that??), sort of a recall, but not exactly.
..guess how long it took me to learn all this internet jargon, especially 'cause my mother language is not English
Anyways, a lot of higher- mileage manual trannys do that, not only on Jeeps but many many others. Usually there's nothing to really worry about it, as you knowhow to double-clutch, you propably know thjis already, but:
a cold tranny/ cold fluid, the synchro rings don't fully function and that's why you get grinding, and that's usually just 1st to 2nd (and sometimes 2nd to 1st as well if you use engine-braking).
Like mentioned, use high-quality fully- synthetic oil and it should reduce that grinding to minimum
***Under construction***
Timo_90xj is offline
post #6 of 10 Old 12-24-2007, 06:54 PM Thread Starter
Mitchell1789
1995 XJ Cherokee
Ok, so Ill put some nice synthetic in it. Yeah, someday I'll learn the jargon around here... But anyways thanks a ton for your help! Happy holidays!
post #7 of 10 Old 12-24-2007, 07:05 PM
Timo_90xj
Timo_90xj's Avatar
No worries
..sorry for the spelling errors, after staying awake for ~18 hours and drinking a few beers after that isn't good for your eyesight
Happy holidays too
post #8 of 10 Old 12-24-2007, 08:46 PM
Grand Fan 4eva
had the same problem when it would get to about -10 or -20 around here. read up on it and switched to redline mt-90. it's much smoother now. still catches a little but its definitely better. i'd recommend it. i ordered mine from summit racing.
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'91 MJ
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline
post #9 of 10 Old 12-25-2007, 10:16 AM Thread Starter
Mitchell1789
1995 XJ Cherokee
Ok, I'll go with that. Sounds pretty good. How many quarts does it take?
post #10 of 10 Old 12-26-2007, 03:08 AM
Lew360
1992 XJ Cherokee
Here is a good write up on changing the oil in an AX-15. He used MTL but I prefer MT-90, especially in warmer climates. Some of the information is TJ specific but you will get the idea.
Lew360 is offline
du du du du grind grind grind - HOT AIR! cherokeeKID XJ/MJ Cherokee Non-Technical Forum 1 10-01-2009 12:58 PM
Which manifold to grind? 94_country XJ Cherokee Technical Forum 2 02-10-2007 09:05 AM
Creak and Grind? Marine_Psycho XJ Cherokee Technical Forum 5 12-01-2006 01:49 PM
Turning Grind lamborn XJ Cherokee Technical Forum 4 02-23-2004 03:44 PM
89 XJ TC Grind Dafly XJ Cherokee Technical Forum 2 09-03-2003 12:37 AM
