1999 XJ dash light problem - JeepForum.com
post #1 of 2 Old 05-03-2010, 04:39 PM Thread Starter
reddemon
1999 FSJ Cherokee
hey. I just bought a 1999 XJ. Didn't get to drive it untill tonight. Found out i have no dash lights. All the gauges work, just the lights don't come on for the insturments or the A/C controls. Dose any have any idea what this could be. Thank.
reddemon is offline
post #2 of 2 Old 05-03-2010, 05:59 PM
midfat
midfat's Avatar
Did you check your fuse? As I recall, it's a 5A fuse for all the dash lights. I installed a lighted trans cooler gauge and that seemed to put me over the top. Started popping fuses left and right. Ended up putting a 7.5A fuse in a while back and that solved the problem.
If there's any aftermarket stuff wired in the dash, I'd start by checking the fuses.
midfat is offline
1999 Cherokee Airbag light stays on DuneBuggy XJ Cherokee Technical Forum 11 06-23-2012 12:32 PM
Dash light problem TheIceMan XJ Cherokee Technical Forum 2 12-02-2009 05:42 PM
1999 Cherokee No Crank, No dash, Lights kurtbr XJ Cherokee Technical Forum 3 07-15-2009 02:36 PM
1999 jeep cherokee check engine light ctchisholm XJ Cherokee Technical Forum 8 06-29-2007 07:18 AM
Dash light problem Prairepup XJ Cherokee Technical Forum 3 04-16-2004 11:24 PM
