#16 | |
a reply to cheer you up.
i want to see this thing lifted, get to work, lol
2011 Chevy Silverado ext cab z71 1988 JEEP Comanche 4x4 shortbed: 4.0L w/ 5spd 6inch RE lift w/ Spring over-8.8 aussie locker and 4.56s High School Jeepers #15 |
#17 |
Yes Man!
thanks for the bump. Started lifting today!!! what a *****! Took 12 hours to remove everything from the rear and were able to put one leaf spring back on. Didnt break a single bolt, but had to cut the two front leaf spring bolts. We ended up reusing the two we didnt cut up from the shackles up front and bought new grade 8s with lock washers and lock nuts for the rear. Worked out great! I know some might flame me for reusing bolts, but i have to get this drivable asap, and ordering new bolts is out of the question right now. Plus my brake lines are corroded and we busted a hardline which we have to fix. All in all it took 12 hours to remove the leaves, rear shocks, rear swaybar, ubolts, and bolt ONE new spring in. We really did not have the tools needed. But anyways here are some pics of in the process. Pretty close to what it looks like now besides the floor being cleaned up and a new spring in. Oh and my new favorite buddy is the angle grinder that i bought.
![]() ![]() ![]() OH and i need to know what to torq the bolts too... Leaf springs: Shocks: Ubolts: |
#18 |
sweet dude, looks like a blast!
#19 |
Drivin' me nuts...
U-bolts - 52 ft lbs
Front pivot bolt - 115 ft lbs upper shackle bolt - 115 ft lbs lower shackle bolt - 80 ft lbs Rear shocks: upper bolts - 17 ft lbs lower nut - 46 ft lbs You think it'll be done today? Can't wait to see it.
'99 Classic: "Emma" 8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents Jeeps with Teeth #1 MN Jeeper #14 _____________________________________________ "When is the best time to do things? Who is the most important one? What is the right thing to do?" "BORN TO WHEEL" PRODUCTS FOR SALE **********More designs here********** |
#20 | |
Yes Man!
#21 |
awesome man. love to see the light blue cherokees lifted.
[U]1994 Jeep Cherokee[/U] SYE,6" RE with tnt y-link long arms, 33x12.5 BFG Mud Terrains, Nates 4x4 custom winch bumper [QUOTE=ktmracer419]either way thats ridiculously peepee enlargingly tall.[/QUOTE] |
#22 |
HAHA
Cant wait to see it finished. Lookin good. I dont know if youve said but, what tires are you gonna run?
-Andrew Another Chero in progress |
#23 |
Do you have an impact gun,? If you dont id suggest getting one. If you dont want to put the cash down for an air setup, an electric one will be pretty good. WOrking with air tools can pretty much cut the work time in half. Looks like fun though... it will definatley be worth the work.
#24 |
Wow, first off, I love the color of your rig. Second, I really admire how neat and tidy everything is. I hope it stays that way! What are your plans in the rubber department?
03 WJ Limited, 4" Zone, 265/75/16 Goodyear Wrangler Duratracs 89 XJ Pioneer: Stock with 31s and a trim. Sold 99 XJ Sport: 2" on 31s with armor and dents. Sold 74 Nova - 2" drop and disc conv. Sold. My videos |
#25 | |
1998 Jeep Cherokee Limited Black 4.0L......AW4 Trans......NP231 SYE......DANA 30 in Front......Corp 8.25 in Rear RE 3.5" SuperFlex, Bushwacker Flat Flares and 33" Goodyear Wrangler Duratracs Black XJ on Moabs Club Member #2
#26 |
HAHA
Hows the lift coming along?
#27 | |
Yes Man!
Ill be running 31x10.5 cooper discoverer STTs on 15x8 cragar soft 8s with 4.0 backspacing and the stock jeep center caps. Ill get a pic of that too, but no tires yet. Oh, and toolwise, we have access to every possible tool we would need. My uncle has a garage full of every tool imaginable, and so does another friend of my mom/dad. We are using a Chicago electric/harbor freight electric impact and it works great! |
#28 |
Yes Man!
Got some pics up. Not the best. The commander was in the way!
First, the hole cut in the floor. That under the rear seat behind the front passengers. ![]() New lock nut, the old weld nut is still there, but we drilled through it. This holds just as great. Im probably going to have this welded to the frame when we get the floor patched back together. ![]() Heres the rear. Its a far as we got. Yielded 5.5" of lift after the SAGGED height was measured. It was sagged quite a bit. ![]() Wheel and center caps. Any ideas for putting the center caps on? ![]() New to us commander and my XJ as it sits with a broken brakeline. ![]() |
#29 | |
Drivin' me nuts...
Keep up the good work!
#30 |
Its looking good. cant wait to see what you have planned for it next!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
