1999 Sport steering issue - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 1999 Sport steering issue
WIN a Rough Country Forged Track Bar - ExtremeTerrain!FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6
Unread 06-17-2013, 09:55 AM   #1
ace064
Just replaced both steering hoses on my 99 Sport and now I have what I call a "catch" in the steering when turning both directions. Could also be described as slight play in the steering. This is directly related to the hose change, since it was perfect before. Any ideas what it could be? Could air in the pump or gear be causing this. It didn't take much fluid to top it off after I changed the hoses.
ace064 is offline   Reply With Quote Quick reply to this message
Unread 06-17-2013, 08:19 PM   #2
pokeyxj
Air in the pump would cause this. Too bleed the system the manual says to turn lock to lock until all the air is pumped out. Did you use power steering fluid, The newer xj's don't like atf in the steering pump.
2000 XJ Limited, 4.5 Rusty's All spring lift; 265/75/16 BFG KM2's; 4.0, aw4, 242.
2001 XJ Sport, 4.5 Rusty's lift, 32x1150x15 Hankook Dynapro MT's. 4.0, aw4, 231, 8.25 rear with power trax locker.
08 f 150 2.5 lift, 33's, arb.
pokeyxj is offline   Reply With Quote Quick reply to this message
