1999 heater core replacement, I need instructions - JeepForum.com
post #1 of 4 Old 11-28-2006, 08:33 AM Thread Starter
wkayl
Anyone have detailed instructions on replaceing the heater core on a 1999 Cherokee? I used to do this sort of thing fo a living back in the 70's, but things have changed.
wkayl is offline
post #2 of 4 Old 11-28-2006, 09:20 AM
anony91xj
I don't think you're going to find detailed instructions, but if you've got mechanical experience it shouldn't be too hard, just time-consuming. Be careful and remember to watch carefully where everything goes as you take it apart.
1998 VW GTI 2.0
anony91xj is offline
post #3 of 4 Old 11-28-2006, 09:30 AM
AZ Jeff
2014 JK Wrangler
Go over to Jeeps Unlimited, and PM a guy who goes by the sig of "Silver XJ". He has a write-up on how to R&R the evaporator on a 2000XJ, and almost all of that procedure applies to the heater core as well.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 4 Old 11-28-2006, 10:06 AM
nylyon
Basically you need to remove the steering wheel and column, center console, and the entire dash. The only special tool you will need is a steeringwheel puller, the rest are just hand tools. It took me about 4.5 hours to remove the unit and 3 hours to put everything together again. You will need 2 people to remove the dash, it's bulky. While the dash is out you may want to tighten all the screws down, I was able to get rid of all my dash rattles as an added bonus.
Karl
2001 Cherokee Limited Patriot Blue *Stock* NP242 4.0 ABS Hidden Hitch, Factory Tow Hooks, Michelin X-Radial
nylyon is offline
99 cherokee heater core replacement tips / low heater output 01xjltd XJ Cherokee Technical Forum 14 06-30-2013 10:53 PM
Advide for Replacing Heater Core in 1999 XJ? sanrico XJ Cherokee Technical Forum 3 02-04-2009 01:43 PM
heater core replacement GRDCHRKE555 XJ Cherokee Technical Forum 23 01-06-2008 03:35 AM
heater core replacement Hristo XJ Cherokee Technical Forum 9 04-13-2006 09:43 AM
XJ Heater Core Replacement tehlers2 XJ Cherokee Technical Forum 3 09-10-2003 09:26 PM
