1999 Cherokee Sport - Heater & AC problems - JeepForum.com
post #1 of 2 Old 01-25-2010, 01:01 PM Thread Starter
CherokeeSport99
Just wanted to see if I could get some feedback on a used 99' Cherokee Sport I picked up.
All in all the Jeep is in good condition. My only complaint is that the heater and AC aren't working correctly.
A brief summary of the problems are;
1. Both the AC and HEATER will only blow if the setting is turned up to 4. If the dial is selected to 3,2,1 it does not blow at all.
2. Heater blows warm air - not hot
3. AC doesn't blow cold
Any Ideas on what might be causing the problems?
Thanks
CherokeeSport99 is offline
post #2 of 2 Old 01-25-2010, 01:06 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Read through the older threads, these are common problems and have been discussed already. The previous threads are all here is waiting for you to discover.
1) Get a new blower motor resistor. Inspect the control panel switch for damage
2) Service the cooling system, drain, flush, new thermostat, re-fill with fresh 50-50 coolant. Flush the heater core.
3) Service the A/C, make sure the R-134a coolnt is fully charged.
CJ7-Tim is offline
Common Problems with 1999 Cherokee Sport? blakely03 XJ Cherokee Technical Forum 25 05-23-2017 12:48 PM
my 1999 cherokee sport sega2010 XJ Cherokee Technical Forum 5 12-09-2009 09:37 PM
1999 Sport Heater blowing outside temperature air dictusm XJ Cherokee Technical Forum 0 09-13-2009 07:58 AM
need help with 1999 cherokee sport caliente XJ Cherokee Technical Forum 10 01-12-2005 04:49 PM
need help with 1999 cherokee sport caliente XJ Cherokee Technical Forum 2 01-11-2005 04:04 PM
