Had this for a while, might be easier to print out. I keep a couple extra tucked inside the panel incase I run into someone like you
1--20 amp.----power antenna relay( 1993). trailer tow relay( 1993-95)
2--15 amp---Brake lights
3--20 amp.---Hazard lights
4--15 amp.--Security lamp
5--15 amp.--interior lighting
6--15 amp.--Security alarm module
7--15 amp.--Security alarm relay, security alarm module, flash- to- pass
8--15 amp.--Overhead console,keyless entry,radio memory/ clock/chime module, power locks, power mirrors, HEVAC and VIC
9--20 amp.--Rear wiper
10--15 amp.(1993) Radio accesssory----10 amp.--( 1994-95) Radio
11--15 amp.--Cigar lighter
12--15 amp.-- Parking lamps, automatic headlights
13--20 amp.--Horn relay
14--20 amp--Power lock relay
15--3 amp--ABS module and relay
16--20--Turn signals
17--7.5 amp.--Heater and A/C module
18--15 amp.--air bag module
19--15 amp.--interior mirror,auto headlamps,ovrehead console,VIC/GDM module,heated rear window relay,ciol,illuminated entry, chime module.
20--10 amp.--heated rear window switch, overdrive switch, speed control.
21--15 amp.--cluster ( 1993) , security alarm module , lamp outage module.
22--15 amp.--Air bag module, speedometer, tachometer, telltales and gauges
23--15 amp.--heated mirror feed, heated rear window switch.
24--7.5 amp.--instrument panel illumination.
25--30 amp.---power seats----( circuit breaker)
26--30--( circuit breaker)--Power windows ( 1993-95) power sunroof ( 1994- 95)
27--10--( circuit breaker)--Security alarm module, front wiper
28--30 amp.--heated rear window relay
