1999 4.0l starts but won't continue to run without gas peddle assist. - JeepForum.com
post #1 of 13 Old 10-22-2008, 08:55 AM Thread Starter
gyurko
My 1999 4.0L with 83K. has started to episodically fail to start without gas being depressed and will not idle without gas feed help. Without gas feed being depressed it will stall. After driving a few minuets it will run normally and start normally until it occurs again. No fault codes come up. Appreciate any suggestions or similar experiences and solutions. Thanks.
gyurko is offline
post #2 of 13 Old 10-22-2008, 09:35 AM
96cherokeeclass
same thing happened to me... believe it or not a new battery fixed it
- 07 WK - CRD
96cherokeeclass is offline
post #3 of 13 Old 10-22-2008, 10:03 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Those are the common symptoms of a bad battery. Take it to a repair shop or parts store and have it load tested.
CJ7-Tim is offline
post #4 of 13 Old 10-22-2008, 10:05 AM
bwoo90
2015 WK
Could be bad gas, could be a TPS, could be alternator going, might try cleaning the IAC.
2015 Jeep Grand Cherokee Overland
2001 Jeep Grand Cherokee
1992 Jeep Cherokee
1988 Jeep Cherokee
bwoo90 is offline
post #5 of 13 Old 10-22-2008, 10:07 AM
scupking
It's a bad IAC trust me. This happened to me on my mustang. It would start sometime without an issue, other times I had to keep my foot on the gas to keep it from dying. After driving it for a few minutes it would idle fine. I replaced my IAC and all is good.
scupking is offline
post #6 of 13 Old 10-22-2008, 10:23 AM
96cherokeeclass
Start with the simplest solution and work your way up
- 07 WK - CRD
post #7 of 13 Old 10-22-2008, 10:28 AM
Cherokee2000
Happened to me twice. Both times it was because my battery was near dead. If your battery is still good, then X3 on your IAC.
Cherokee2000 is offline
post #8 of 13 Old 10-22-2008, 11:18 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Testing is best way to figure this one out. Start with battery, then TPS IMHO.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #9 of 13 Old 10-22-2008, 11:23 AM
kadetklapp
1997 XJ Cherokee
Unhook the battery and then hook it back up and see what happens. If not then I would guess TPS.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #10 of 13 Old 10-22-2008, 11:40 AM
jebmccall
1997 XJ Cherokee
thats happens to me when ever my battery dies i have to help it idle for a few minutes, and then all is good
jebmccall is offline
post #11 of 13 Old 10-30-2008, 09:05 AM Thread Starter
gyurko
Thanks for all the advice everyone. I discovered that the battery termnals were dirty and cleaned tham up and have driven the vehicle for the past week without a glitch. Never would ahve suspected that the no idle situation could be caused by low battery output.
gyurko is offline
post #12 of 13 Old 10-30-2008, 10:55 AM
bwoo90
2015 WK
Thank-you for coming back with a follow-up. All too often we never hear back.
bwoo90 is offline
post #13 of 13 Old 10-30-2008, 03:54 PM
collkid
Dang that is kind of weird, good thing to know.
2000 Jeep Cherokee. 4.5', Long arms, Bumpers front and rear, Winch.
1992 Toyota Paseo DD 35+ MPG
Colorado Member #89
collkid is offline
2.5 wont idle unless pump gas peddle GooberTard XJ Cherokee Technical Forum 7 09-17-2009 12:08 PM
4.0 starts but low rpm's and now starts and stalls Radium08 XJ Cherokee Technical Forum 1 07-22-2009 01:53 PM
Jeep troubles continue... shifting Thmastr XJ Cherokee Technical Forum 3 12-27-2007 12:49 AM
Hydro Assist? XJ Jeremy XJ Cherokee Technical Forum 1 09-05-2007 09:15 PM
Brake peddle tapping sjns XJ Cherokee Technical Forum 10 02-09-2004 09:40 AM
