1998 XJ - Odometer reads 'NO BUS' - JeepForum.com
post #1 of 4 Old 03-30-2011, 12:10 PM Thread Starter
I have a 98 cherokee sport and all of my guages work EXCEPT the Odomiter, it does not say "no bus" and there are no running conditions.
any ideas of what is wrong? what ground controls the guage?. i could use a guage schematic if anybody has one. or any other ideas or pics would help thank you!
Timstock is offline
post #2 of 4 Old 03-30-2011, 06:48 PM
Resident McGeek
BeachinXJ's Avatar
Usually, if nothing on the jeep is not working / running poorly other than the cluster, it's the connection on the back of it. You need to take the dash apart, and remove the connection on the back of the cluster. Clean it, apply a little dielectric grease, and reassemble. Should be good to go.
2000 Jeep XJ - Chopped / Locked
1997 Jeep XJ - Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Join the XJ Owners Club | Download the iMarn® iPhone App!
SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather!
Homepage | Jeepspace Group|Twitter!|Facebook
BeachinXJ is offline
post #3 of 4 Old 03-30-2011, 06:52 PM
Mine did this 2 years ago. I did just like Beachin said and it hasnt done it since.
Friends dont let friends do DUBS.
XJcruiser is offline
post #4 of 4 Old 03-31-2011, 05:21 AM
It's the crank sensor!
tjwalker's Avatar
Yup. Follow guidance from above and you should have a good chance of resolving this.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
cluster , guages , No bus , odometer , odometer problem , xj
Odometer reads NO BUS, plus rocker panel ? RicheB413 XJ Cherokee Technical Forum 5 09-24-2010 06:00 PM
86 XJ tach reads wrong 2point8 XJ Cherokee Technical Forum 1 10-17-2008 04:41 PM
99 XJ temp gauge reads 0 Xjcrusader XJ Cherokee Technical Forum 3 10-30-2007 06:43 PM
99 xj code reads: no bus BAJAMAN XJ Cherokee Technical Forum 6 05-03-2006 01:54 AM
Since nobody reads the other forum.... Mr98Pontiac XJ Cherokee Technical Forum 2 11-12-2002 12:12 PM
