1998 jeep Cherokee sport. Help - JeepForum.com
post #1 of 13 Old 06-26-2011, 12:47 PM Thread Starter
Wesly_66
1997 XJ Cherokee
Hey guys I need some help. About 2 minutes after I start up my jeep it has no Power it barely stays running. It lasts for about a minute or less and after that everything is good. I have replaced the fuel pump, tps, cps, spark plugs and wires. All those parts have been replaced in the last 5 months. This problem started happening about 2 weeks ago. Any help is appreciated. I drive a 1998 jeep Cherokee 4.0 5 speed
Wesly_66 is offline
post #2 of 13 Old 06-26-2011, 01:06 PM
js_pak
1995 XJ Cherokee
try getting your battery and alternator checked. a lot of places will do it for free. i had similar symptoms on my WJ. ended up being a bad battery.
2004 Grand Cherokee WJ Overland 4.7 HO V8 2WD Automatic (DD), 30" BFG AT
1995 Cherokee XJ Country 4.0 l6 4WD 5 Speed Manual, RC 3 in lift, 31" BFG MT KM2
- My enemy is anyone who is going to get me killed, regardless of whose side they are on.
js_pak is offline
post #3 of 13 Old 06-26-2011, 01:40 PM Thread Starter
Wesly_66
1997 XJ Cherokee
I just got my alternator rebuilt to 190 amp. I am supposed to put a bigger power wire on it and I haven't yet. Could it be that? And he checked my battery right away he said it should be good till fall.
Wesly_66 is offline
post #4 of 13 Old 06-26-2011, 01:52 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
How did you get the alternator to 190 amps?
xjfever is offline
post #5 of 13 Old 06-26-2011, 02:31 PM Thread Starter
Wesly_66
1997 XJ Cherokee
Close to where I live there's a guy that rebuilds starters and alternators for a living. He had built a jeep Cherokee alternator before to 190 amp for a guy that was doing sound competitions with 8 12" subs. He changed the case on it to a little bigger one and changed a bunch of internals. Not sure what all. But he did a good job
Wesly_66 is offline
post #6 of 13 Old 06-27-2011, 12:38 AM
sbxj
sbxj's Avatar
maybe not
have it tested independently
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #7 of 13 Old 06-27-2011, 02:08 AM
billabongopblue
Are the parts OEM? also check and clean your IAC and throttle body.
96 Classic - 3" Lift - 31" BFG AT's - 29 spline 8.25 - 4.10's - Tow Hooks - RE track bar - RC Dif Guard - Cowl Intake - LeBaron Vents - Dynomax Catback - IRO H&T
billabongopblue is offline
post #8 of 13 Old 06-27-2011, 06:22 AM
AmbuGrl
AmbuGrl's Avatar
Definately have your alternator and the battery checked by a third party
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #9 of 13 Old 06-27-2011, 10:02 PM Thread Starter
Wesly_66
1997 XJ Cherokee
He tested it and showed. But what I'm wondering is why does it only do it like a minute or two after I start it up? And only lasts less than a minute
Wesly_66 is offline
post #10 of 13 Old 06-27-2011, 11:11 PM
neeland
Originally Posted by billabongopblue
are the parts oem? Also check and clean your iac and throttle body.
x2
neeland is offline
post #11 of 13 Old 06-28-2011, 10:49 PM Thread Starter
Wesly_66
1997 XJ Cherokee
How long do injectors usually last? My jeep had 260,000 kilometers and it's starting to slow down.
Wesly_66 is offline
post #12 of 13 Old 06-29-2011, 12:35 AM
Reptile
1991 XJ Cherokee
Coolant temp sensor?
Reptile is offline
post #13 of 13 Old 06-29-2011, 02:21 AM
BlackedOutXJ
I would strongly recommend changing the O2 sensor(s)... I had a similar issue for about 3 years and changed almost every sensor, plugs, wires, coil, distro cap, rotor button, all vacuum lines, etc... Mine was bank one.. first one after the header
BlackedOutXJ is offline
cherokee , no power
1998 Jeep Cherokee sport Stalls ewbenton XJ Cherokee Technical Forum 25 08-26-2015 04:24 PM
1998 Jeep Cherokee Sport 4WD crs46 XJ Cherokee Technical Forum 7 06-22-2011 11:14 AM
1998 jeep cherokee sport juan0548 XJ Cherokee Technical Forum 5 06-22-2011 02:55 AM
1998 Jeep Cherokee Sport Utility SE 4D 4x4 6cyl searcherrr XJ Cherokee Technical Forum 16 06-14-2008 02:34 AM
1998 Jeep Cherokee Sport & Seats - help smokingun XJ Cherokee Technical Forum 3 12-04-2003 05:42 AM
