1998 Jeep Cherokee Limited cranks but wont start - JeepForum.com
post #1 of 6 Old 02-25-2010, 06:49 AM Thread Starter
Dottie
Hello, I have a 1998 Jeep Cherokee Limited with keyless entry. This past weekend I left the dome light on and therefore my battery went completely dead. I tried to jump start it with my husbands battery charger/booster. It cranks but no fire and the gas gauge wont come up like it usually does. When I turn the key over right before I try to crank the engine I can hear a click from the fuse box on the passenger side. It may have always done this but just now noticed this. Any help or suggestions would be greatly appericated.
thank you,
Dottie
Dottie is offline
post #2 of 6 Old 02-25-2010, 10:05 AM
XJH-007
XJH-007's Avatar
Welcome to the forums Dottie!
If all was well before the battery went dead and now it's doing this, it's probably still a REALLY DEAD battery.
Charge it overnight, swap it out with a different vehicles battery, OR try using jumper cables. Low batteries/bad connections have been known to do really strange things.
The click you hear sounds like the fuel pump relay kicking or trying to kick on. The booster charger may have enough current to run the starter but may not have enough for the starter and fuel pump.
When the charger/booster is connected, and the key is in the 'run' position, the fuel gauge shows no fuel? (dumb question I know) Are you out of gas?
Scott-Crawlorado Native
I have an addiction.....
*00' XJ_T-n-T Y-Link/6" RE_OME's_33" KM2's
Tera 4:1 / 4:56's_Elec. Locked D44
**84' CJ7 4"BDS 33's
***02 WJ Overland
XJH-007 is offline
post #3 of 6 Old 02-25-2010, 10:37 AM
My1989Jeep
1989 XJ Cherokee
Get a good battery first, charge it up or buy a new one. Once you do that check for spark. Take out one of the spark plug wires stick an old apark plus in it and hold it to the engine and have someone crank it. If no spark it might be the module or coil. If it has spark then disconnect the air filter hose from the throttle body and spray some carb cleaner in there, then have someone crank it, if it starts then fuel pump out.
1st 1989 Jeep Cherokee Laredo. 4 Door. Automatic. 4.0L Straight Six.
My1989Jeep is offline
post #4 of 6 Old 02-25-2010, 02:36 PM Thread Starter
Dottie
Hello, thank you for your responses . The battery did charge, after the jeep failed to start it was put on slow charge and it shows that it is fully charged, and I just filled it up with gas the last time I drove it. The battery was fully charged and still no spark, cranks over well, but still no gauges work. Could the keyless entry have something to do with the problem?
thank you for your help
dOTTIE
Dottie is offline
post #5 of 6 Old 02-25-2010, 02:40 PM
My1989Jeep
1989 XJ Cherokee
Check to see if you are getting power to the fuses inside the Jeep. Then check the spark on the spark plug wires, then check if you hear the fuel pump turn on. (Do this by turning the key to the on position but dont crank it. Have someone under the jeep near the tank see if they hear it.)
post #6 of 6 Old 02-25-2010, 02:57 PM
csouers
The keyless system may be disabling start up. Close all the doors and hood, then fully lock and unlock the jeep with the remote. Now see if the Jeep'll start.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
HELP - Jeep cranks but wont start ViRaL XJ Cherokee Technical Forum 12 07-19-2014 05:53 PM
cherokee cranks over but wont start please help amazingman XJ Cherokee Technical Forum 7 03-31-2009 10:40 PM
1997 Jeep Cherokee 4.0l won't start, cranks good. gearhead68 XJ Cherokee Technical Forum 2 08-31-2008 10:55 PM
1998 Cherokee Classic wont start Ahriman XJ Cherokee Technical Forum 1 05-13-2008 10:45 AM
93 Cherokee 4.0HO - cranks, but wont start bmason11 XJ Cherokee Technical Forum 6 01-18-2007 08:28 PM
