1998 Jeep Cherokee Classic wont start.. - JeepForum.com
post #1 of 4 Old 03-26-2011, 02:48 PM Thread Starter
flipadelphia37
So about 2 months ago, to get my jeep to start I had to move the gear shifter around. This continued to happen. I talked to some people and read about it probably being the neutral safety switch. Well I had yet to change it out. Today when I went to start the Jeep I just heard a very fast clicking noise and it didnt start. I had full power as far as radio and lights but it would not start. I immediately thought the neutral safety switch had final crapped out. I changed out the NSS in about 2 hours and now cannot get my jeep to start. I should have realized initially that the clicking noise was not the neutral safety switch. I turned the gear coming out of the motor block (turing the whole serpentine belt) to try and get the starter to catch and hopefully start the car. Still nothing except this time I was only getting one quick clicking noise. Im now again hearing the VERY fast clicking noise and nothing else. The starter is also brand new (only 4-5 months old). Any help would be great because I sure as hell dont want to take it in and pay an arm and a leg. Thanks guys...
flipadelphia37 is offline
post #2 of 4 Old 03-26-2011, 03:19 PM
keepishop
1989 XJ Cherokee
Clean your battery terminals and connectors. Clicking means low voltage, fyi. If that does not fix it, Clean all of the engine grounds. If it still doesn't work, try another battery.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #3 of 4 Old 03-26-2011, 03:24 PM
96upcountry
^^X2 What he said
96 XJ Country NP242 Upcountry suspension package
Originally Posted by cruiser54 View Post
Looking at grounds doesn't count. You MUST remove, scrape, polish, clean and then reattach. Otherwise you're wasting your time. Unless of course, you have the ability to see electricity flow.............
96upcountry is offline
post #4 of 4 Old 03-26-2011, 04:23 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
These problems are relatively simple to diagnose, and it really helps if you have a meter and have a fundamental knowledge of how to use it.
Always start with removing battery cables, cleaning them and the battery posts until SHINY. Connections as mentioned by others, are often suspect. Then LOAD TEST the battery. It is the only accurate way of determining battery condition.
Okay, still doing it AFTER the above is verified? Get that meter. Buy one if you don't own one. Everybody that works on their XJ needs to own a meter. With the key in the on position, put the meter directly on the starter. You should have approximately full battery voltage there.
If you have full battery voltage at the starter, the problem is THE STARTER. Even if it is newer.
However, if you don't have full battery voltage at the starter, you have to start working your way back into the engine bay to find out why. Common causes include a bad cable, bad ground, connection, etc.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is online now
1998 Jeep cherokee classic won't idle consistently corbin9191 XJ Cherokee Technical Forum 12 04-21-2015 06:51 AM
1998 Cherokee Classic 4.0L wont start! Andrews_92 XJ Cherokee Technical Forum 2 03-06-2011 12:26 PM
1998 Jeep Cherokee Limited cranks but wont start Dottie XJ Cherokee Technical Forum 5 02-25-2010 01:57 PM
1998 Cherokee Classic wont start Ahriman XJ Cherokee Technical Forum 1 05-13-2008 09:45 AM
1998 Jeep Cherokee Classic Jake XJ Cherokee Technical Forum 0 07-10-2001 03:09 PM
