1998 Cherokee Sport BRAKE LINE REPLACEMENT - REAR - JeepForum.com
post #1 of 1 Old 05-23-2011, 12:56 PM Thread Starter
GodsUnholySin
1998 FSJ Cherokee
I have a 1998 Cherokee Sport four door. 4.0 L stright 6 engine, automatic transmission. my brake lines blew leaks last week. I have been able to replace the front line with out any real issues, my problem is replacing the brake line from the master cylinder to the rear brakes, i got the front undone, pulled the line away from the line holders, went to undo the rear fitting and i do not have enough room to even use a socket set. and idea on how to do this? I was also wondering if i could just bleed the brakes as normal or if i had to do something diffrent or special when i got the new lines on and ready to go. I drove about 15 miles or so down shifting and using my hand brake because i had to get home to my child. any help would be awsome.
GodsUnholySin is offline
brake lines , brakes , rear brakes
93 Cherokee Hard brake line replacement - Autozone.. parrothd XJ Cherokee Technical Forum 5 02-07-2015 12:30 PM
1998 XJ Rear Brake Line Help jonboilard XJ Cherokee Technical Forum 4 12-03-2008 08:36 AM
1998 Cherokee Sport. Please Help ME! bermudaJEEP MJ Comanche Technical Forum 16 11-19-2008 07:46 PM
Brake line replacement.....rear flex line Captainkirk XJ Cherokee Technical Forum 1 10-26-2008 01:43 AM
1998 cherokee sport rear axle will_coop XJ Cherokee Technical Forum 5 01-03-2008 06:15 PM
