1998 Cherokee 4.0 rough idle - JeepForum.com
post #1 of 13 Old 08-03-2011, 09:36 PM Thread Starter
rustyabiding
1989 XJ Cherokee
Hi Im baffled by this problem. Im working on a friends 1998 Cherokee and it has a really rough idle but when you accelerate it runs just fine. I ran the codes and it says bank 1 misfire and bank 3 misfire. I replaced the TPS and the IAC because another jeep i worked on had a similar problem and that fixed it. Could it be something with fuel Pressure? Or what else could it be??
Thanks
Rustyabiding
rustyabiding is offline
post #2 of 13 Old 08-03-2011, 11:08 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are all the tune-up parts new or have less than 30,000 miles ? Used any fuel injector cleaner in the gas tank ? Tested the fuel injectors and inspected their wires ?
CJ7-Tim is offline
post #3 of 13 Old 08-03-2011, 11:13 PM
EricsXJ
The Post man
EricsXJ's Avatar
- clean fuel injectors (stated above)
- clean throttle body
- put a can of Seafoam in the intake and gas (can also help with the above two suggestions)
The Seafoam treatment did wonders for our '97 that had a very rough idle that would also cause a misfire on occasion.
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #4 of 13 Old 08-04-2011, 06:31 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Start with fresh Champion copper plugs gapped to .035, new plug wires, distributor cap and rotor.
Failing to freshen tuneup hardware when symptomatic often results in the chasing of your tail.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #5 of 13 Old 08-04-2011, 03:49 PM Thread Starter
rustyabiding
1989 XJ Cherokee
Ok Ill try all those suggestions, When I looked at all the plugs, wires, cap and rotor they didnt seem that bad but looks can be deceiving I guess haha. Ill update when im finished, Thanks!
Rustyabiding
post #6 of 13 Old 11-12-2011, 01:25 PM Thread Starter
rustyabiding
1989 XJ Cherokee
I put in new plugs, wires, cap, rotor, and seafoamed it. It didnt make one bit of difference. Still does its chug chug chug chug chug chug chug constantly. How do you test the injectors? Or could it be something more serious?
Rustyabiding
post #7 of 13 Old 11-13-2011, 12:18 AM
Reptile
1991 XJ Cherokee
You can tests the injectors by swapping them (swap #1 and #3 injectors, put them elsewhere). If the codes follow the banks where you put the injectors, then you know.
Reptile is offline
post #8 of 13 Old 11-13-2011, 05:14 PM Thread Starter
rustyabiding
1989 XJ Cherokee
Ok That makes sense, Ill try that Thanks!
Rustyabiding
post #9 of 13 Old 11-13-2011, 05:56 PM
Absolutexero
2009 JK Wrangler
could be the map sensor
"Don't ask questions you don't know the answer to."
Absolutexero is offline
post #10 of 13 Old 11-13-2011, 11:58 PM
Reptile
1991 XJ Cherokee
I was actually thinking that (MAP or vac leak). Probably the next thing to check after the injectors.
Reptile is offline
post #11 of 13 Old 11-14-2011, 07:06 AM
AmbuGrl
AmbuGrl's Avatar
Check the wires from your upper O2 sensor to make sure they arent damaged.
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #12 of 13 Old 11-14-2011, 01:23 PM
optdoug
optdoug's Avatar
2006 WK
Reset the computer by disconnecting the battery. Leave it disconnected for a few minutes then reconnect.
If the timing in the computer is off, it will reset and relearn the timing. This may or may not be the problem, but it's the simplest thing to do before you go throwing money at it and spending hours troubleshooting.
optdoug is offline
post #13 of 13 Old 03-26-2012, 11:53 AM Thread Starter
rustyabiding
1989 XJ Cherokee
Sorry It took so long to get back, I got hurt and have been laid up for months but I replaced all the injectors and still no change. I think it could be something with the head or the timing chain????
Rustyabiding
Jeep Cherokee has rough/low idle and is stalling hotmomma XJ Cherokee Technical Forum 43 01-11-2016 11:05 AM
1998 Jeep cherokee classic won't idle consistently corbin9191 XJ Cherokee Technical Forum 12 04-21-2015 07:51 AM
Rough Idle on '99 Cherokee--TPS XJER XJ Cherokee Technical Forum 7 10-02-2007 10:19 PM
1992 cherokee rough idle - fixed bdhaley XJ Cherokee Technical Forum 0 11-10-2005 04:13 PM
HELP!!!! 91 jeep cherokee 4.0 Extremely Rough Idle dspivey XJ Cherokee Technical Forum 1 04-16-2005 09:09 PM
