1997 XJ NP242 question - JeepForum.com
post #1 of 7 Old 09-21-2010, 10:40 PM Thread Starter
mtnbiker326
I have been having some trouble with my NP242 lately. It is rediculously hard to switch from 4wd (any type) back into 2wd. You put the lever in and it stays 4wd for a long time. The only way I have successfully found to disengage the 4wd is by placing the truck in reverse and floor it for about a second or so. It disengages and I have 2wd again.
I also notice that when I put it in 4wd (FT) fulltime, it acts just as if it was in part time (PT). It is like I have a np231 with an extra lever pull to get it into 4wd. It engages in part time and full time but just acts like it is in part time only.
Any thoughts or explainations for this? Should I start with a master rebuild kit?
Thanks.
mtnbiker326 is offline
post #2 of 7 Old 09-21-2010, 10:47 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
the first thing i would try is to adjust the linkage. search the forum for the procedure
1990JEEPXJ is offline
post #3 of 7 Old 09-21-2010, 10:47 PM
alexrule123
alexrule123's Avatar
Have you tried adjusting the linkage? I found that for me if I get the tcase into neutral and then loosen the bolt on the linkage it works awesome and then tighten it of course. Keep in mind the 242 can be a pain to switch out of full time, I usually coast in neutral and then pull up a little on the e-brake and it pops right back into 2wd.
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #4 of 7 Old 09-22-2010, 02:43 PM
MegaTherion
As for not coming out of 4wd into 2wd. Check your tire pressure, or uneven tire wear.
Mine would not come out of 4wd as you mentioned because I had two different manufacturers of tires front and back, I believe causing the t-case to bind slightly(242 is sensitive to this). As soon as I bought 4 new identical tires the problem went away.
MegaTherion
1987 YJ - Chev 350/700R4/Dana 300 Dana 44s,
1999 XJ - 4.0L/AW4/NV242 daily driver, 2004 KJ - Rocky Mountain Edition
MegaTherion is offline
post #5 of 7 Old 01-09-2011, 02:08 PM
konatown69
I know I'm digging up an old thread here, but to the OP, did you ever solve the issue? I am currently having a similar issue and am wondering if adjusting the linkage helped at all?
Thanks
____________
1999 Cherokee Classic, 4.0, AW4, Np242 {HP30 & 8.8 4.56's & locked - build under construction}
konatown69 is offline
post #6 of 7 Old 01-09-2011, 11:33 PM Thread Starter
mtnbiker326
Yes it worked like a charm. Found the linkage was just 1/4" off an retightened. It has not failed yet and that is 4x4ing once a week for the past 3 months
post #7 of 7 Old 01-10-2011, 12:35 PM
konatown69
Sweet, I'll have to give that a try.
____________
ft , full time , np242 , xj
np242 HnT question JxC_XJ94 XJ Cherokee Technical Forum 5 04-05-2010 02:37 PM
96+ np242 sye question theglowingbus XJ Cherokee Technical Forum 14 07-11-2009 11:48 PM
NP242 Selection question? Silent XJ Cherokee Technical Forum 3 01-25-2009 06:06 PM
NP242 4WD Question Skipsjh XJ Cherokee Technical Forum 8 12-14-2008 08:45 PM
Quick question on np242 TC heathcliff1962 XJ Cherokee Technical Forum 3 01-12-2008 08:23 PM
