1997 Jeep Won't turn over - JeepForum.com
post #1 of 20 Old 10-22-2010, 03:49 PM Thread Starter
Shayne1072
Okay so...
What we've done so far..
Ignition-New
Computer-New
Neutral- Checked
Security- Checked
The lights and all dash lights come on but the engine won't turn over. Went to the store, came back, next day it was just dead. At a loss
Shayne1072 is offline
post #2 of 20 Old 10-22-2010, 03:55 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Be specific: 1) Does the starter engage and turn the engine over ? 2) Does the engine Fire up and run, a little bit, or not at all ?
CJ7-Tim is offline
post #3 of 20 Old 10-22-2010, 04:01 PM Thread Starter
Shayne1072
Starter engages...the engine doesn't crank at all. Used a voltage tester, followed every wire around, nothing lose, nothing disconnected....no idea.
post #4 of 20 Old 10-22-2010, 04:04 PM
CJ7-Tim
CJ7-Tim's Avatar
CJ7-Tim is offline
post #5 of 20 Old 10-22-2010, 04:59 PM Thread Starter
Shayne1072
Youre like the Jeep God lol. I will try all of these in the morning. Thanks for the help!
post #6 of 20 Old 10-23-2010, 02:18 PM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Shayne.....Gotta say I'm a bit confused here.
You mention that "the starter engages, but the engine doesn't crank at all". That is where the confusion comes in, as that is kind of a contradiction in terms.
By the way you describe it, it sounds like the engine does NOT turn over. Is this correct?
If that is the case, the problem could indeed be electrical (cables, battery, voltage drop, relays, etc) but this problem would not be related to the crank sensor.
The crank sensor would come into play if the engine turns over normally, but doesn't actually fire up/start.
Lets make sure we're all on the same page here so we can give you the most accurate help.
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #7 of 20 Old 10-23-2010, 04:21 PM
Spencer43783
X2
I was confused by that as well. If it cranks/turns over/starter engages all day you should test for spark/fuel. No spark or fuel your most likely culprit is the CKP. If all you get when you turn the key is 'click' it's what TJ mentioned.
1998 Cherokee Sport 4.0L-AW4-NP231-C8.25--Black, trim removed and chopped. 31" Goodyear Wrangler Duratracs. 3" lift coming soon.
1984 Grand Wagoneer--Sold. I'll miss the old girl.
Spencer43783 is offline
post #8 of 20 Old 10-23-2010, 04:31 PM Thread Starter
Shayne1072
NO crank....Turn the key and nadda.
post #9 of 20 Old 10-23-2010, 04:40 PM Thread Starter
Shayne1072
When turning the key...the starter clicks you can hear it clear as day, but it "sounds" like there just isn't enough juice to turn it over. Starter is new by the way...Battery full charge. The dealer said that it doesn't sound like a Crank shaft sensor. I'm not even going to bother bringing it in because by the sounds of what i've read on the forums, the shops have no idea about Jeeps.
post #10 of 20 Old 10-23-2010, 04:45 PM
tjwalker
tjwalker's Avatar
Okay, here is what I would do if it were my vehicle.
Get a multimeter. With the ignition key in the ON position, get a voltage measurement at the starter itself.
If the voltage at the starter isn't about the same as the battery itself, you are experiencing VOLTAGE DROP, due to a bad cable, connection, ground etc. somewhere between the engine bay/battery and the starter.
Start there. It is what a shop technician would do early in the troubleshooting process.
tjwalker is offline
post #11 of 20 Old 10-23-2010, 04:47 PM
Spencer43783
If you just replaced the starter that's the first place I would look-double check the connections. Check your fuses/relays. Have your battery load tested so you'll know if your CCAs are high enough to start the Jeep.
post #12 of 20 Old 10-23-2010, 05:59 PM Thread Starter
Shayne1072
Checking starter in the morning....
post #13 of 20 Old 10-24-2010, 09:03 AM Thread Starter
Shayne1072
Starter tested fine. Side note that I JUST realized: no radio, no heat blower, no dash light, no whipers, no power to cig lighter. Fuse BOX checks fine. No idea with Jeep, first one.
post #14 of 20 Old 10-24-2010, 02:47 PM
AZ Jeff
2014 JK Wrangler
You probably have a bad ground. Check the battery cables at BOTH ENDS for being clean and tight.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #15 of 20 Old 10-25-2010, 09:01 PM Thread Starter
Shayne1072
If this helps anyone:
I now have dash lights and dome lights after messing with the relays. When I turn the headlights and dome lights on and turn the key, the lights "don't" dim at all. I'm thinking that there isn't power reaching the starter.
1997 jeep cherokee jebmccall XJ/MJ Cherokee Non-Technical Forum 14 05-14-2010 08:20 AM
1997 Jeep Cherokee 4WD Vibration Mule Brain XJ Cherokee Technical Forum 2 02-27-2008 07:38 AM
1997 Cherokee SE won't turn over nsurfass XJ Cherokee Technical Forum 1 06-11-2007 08:43 PM
My 1997 Jeep Cherokee Country 4x4 StokedXJ11 XJ Cherokee Technical Forum 6 08-28-2005 01:04 PM
1997 jeep cherokee bruce7833 XJ Cherokee Technical Forum 3 05-06-2005 08:50 AM
