What does " battery accessories" mean on a 1997 Jeep Cherokee Sport? Have a short somewhere and when I pulled that fuse the light showing the short went off.
Can someone also tell me what color the wires would be in the drivers door wiring harness that supply power to the door lock switch?
Thank you in advance for any help.
What do you mean when you say "What does "battery accessories" mean" ? Where are getting this term from ? What fuse number did you pull, where is this fuse located, and where are you seeing this "light showing the short went off." ?
I think the first thing you need to do is determine if you have a Cherokee or a Grand Cherokee.
The title says Jeep Cherokee Sport. The term "battery accessories" is in the cover over the fuses under the hood. The light is the test light that is hooked between the positive post and the removed from battery positive cable.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
