1996 XJ over heating problem. - JeepForum.com
post #1 of 3 Old 10-01-2012, 06:44 PM Thread Starter
ben322
I have a 1996 Jeep Cherokee sport 4.0L I6 with A/C. When driving the car runs at about 180-190 range but at a light or long stop it slowly creeps up to redline were i have to shut it off. i have both the mechanical fan and E fan but the E fan only runs with the A/C on which makes it over heat quicker so i don't use it. i think it may need a water pump? does this sound possible?
ben322 is offline
post #2 of 3 Old 10-01-2012, 06:51 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Have you checked your fan clutch? Also check your radiator cap.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #3 of 3 Old 10-01-2012, 07:37 PM
cherokee51890
I also had this problem
Either the sensor is no longer good that turns the e fan on or the computer on the jeep isn't turning the fan on anymore. Mine is that the computer no longer activates the e fan. So what I did was run a wire for the fan with an inline fuse and I now manually turn the fan on,which I prefer because I do hit the beach a lot and its nice to be able to control the fan to keep the truck cool. Also I took the mech fan out and put dual e fans in. Which I love. Hope that helps as it should as long as all other components of your cooling system are up to par
cherokee51890 is offline
2wd , 4.0l , cherokee , sport , xj
1996 Cherokee 4.0 Says its over heating but im skeptical RestoringDadsCJ XJ Cherokee Technical Forum 8 08-15-2012 07:52 AM
1996 Jeep heating issue? Buddy101 XJ Cherokee Technical Forum 0 03-30-2012 07:47 AM
1996 runs but wont start after heating. Buddy101 XJ Cherokee Technical Forum 0 03-29-2012 11:02 AM
1996 Jeep Grand Cherokee Laredo V8 5.2 AWD Over heating while Idle TonyJeep XJ Cherokee Technical Forum 2 09-02-2011 04:07 PM
heating problem mikcro1 XJ Cherokee Technical Forum 3 12-11-2007 12:39 PM
