1996 XJ diagnostic code 72 - JeepForum.com
post #1 of 5 Old 10-13-2006, 07:18 PM Thread Starter
artboy
artboy's Avatar
96XJ...check engine light came on last night while driving in the major snow storm here... pulling code #72.. catalytic converter circuit...the weird thing is I just took the XJ into the dealer for a recall repair (E22) about a week ago... they reprogrammed the PCM so it can detect a bad cat... Is it possible the cat was bad even though they said it was OK? if so, why did it take over a week for the CEL to go on? Is #72 something a bad O2 sensor would trigger?.... could the VERY deep wet snow have shorted something like the o2 sensor? Any advice is appreciated so I can go to the dealer with info.
1993 XJ Sport RIP (Parts) - 189k, white, 4.0, automatic, command-trac NP231
1996 XJ Sport Daily Driver - 190k, stone white, 4.0, automatic, selec-trac NP242.
2005 Wrangler Rubicon Summer Toy - 26k, 100% STOCK...silver, automatic, soft and hard tops and doors
"life moves pretty fast... if you don't stop and look around once and awhile, you could miss it"...F. Bueller
artboy is offline
post #2 of 5 Old 10-14-2006, 07:50 AM Thread Starter
artboy
artboy's Avatar
bump back to the top...anyone?...anyone?
artboy is offline
post #3 of 5 Old 10-14-2006, 08:43 AM
rob92xj
1992 XJ Cherokee
The recall is to reprogram the PCM to detect a bad cat and the inspection of the cat is to make sure it is not rattleing. If it is or was rattleing then they would have replaced the cat-converter also. I've done about 40 of this recall in the past month.
The code should have had a "P" number the 72 is a hex code and really don't mean much but if it has a description then it has a meaning but we trouble shoot with the "P" codes.
I think it is more of a O2 sensor code as there are no electrial circuits in a cat converter.
rob92xj is offline
post #4 of 5 Old 10-14-2006, 09:39 AM Thread Starter
artboy
artboy's Avatar
the onboard diagnostic flashed a 72... the description is bad catalytic converter circuit...I am also assuming it is a bad O2 sensor... guess i'll have to wait to get it scanned to find out exactly what is going on
artboy is offline
post #5 of 5 Old 09-10-2012, 07:39 PM
jeepgirl08
Bumpity... I also have this code on my 1997 XJ. More specifically, it's reading P0420.
Any other ideas what this could be other than the 02 sensors? That's our first route but I always like a Plan B
jeepgirl08 is offline
1997 Jeep Cherokee Country Diagnostic Code 43 nohiogal XJ Cherokee Technical Forum 3 05-24-2013 06:32 AM
Throwing Engine Code(Spliced into Diagnostic box wires causing it?) JTrue XJ Cherokee Technical Forum 3 08-30-2008 04:45 PM
OBD-II Diagnostic Trouble Code - P0463 cmassey_2006 XJ Cherokee Technical Forum 2 11-06-2006 10:55 AM
Check Engine Light but no Diagnostic Code? jspringer4 XJ Cherokee Technical Forum 8 10-14-2006 08:56 AM
Diagnostic code without Engine light? Jmaas XJ Cherokee Technical Forum 1 09-25-2002 11:06 AM
