1996 jeep help replacing exhaust! - JeepForum.com
post #1 of 8 Old 03-09-2011, 07:25 PM Thread Starter
t3553r
EXHAUST WON'T FIT! (1996 Jeep Cherokee)
okay so first of heres some background info
The Car:
1996 Jeep Cherokee 4.0L 4WD
The Parts:
autozone maremont tail pipe
autozone super-c muffler
The Problem:
According to autozone the above parts are OEM fit which I understood to mean they should fit with any issues...Unfortunately for me the tailpipe and both ends of the exhaust pipe are 2 1/4" meaning the tailpipe doesn't slip over the muffler or vice versa. On the cat side I have the same problem...the muffler and cat have the same diameter hole and thus I cannot slip the cat over the muffler...Could someone please enlighten me as to how this is supposed to be done? I was under the impression this wasn't welded as the microfiche show clamps holding it on. Is autozones computer simply wrong and these parts are the wrong diameter? Any help is much appreciated!
t3553r is offline
post #2 of 8 Old 03-10-2011, 06:59 AM
hyperboarder
1992 XJ Cherokee
Couldn't you just use a 2-1/4" coupler with some clamps? Seems doable.
hyperboarder is offline
post #3 of 8 Old 03-10-2011, 08:06 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
they sell adapters to do this without welding, which is how I did mine. Get them so one end fits over the upstream pipe, and fits into the downstream one. You will need 2 clamps per splice point.
like this:
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #4 of 8 Old 03-10-2011, 09:13 AM
Jeep_Runner_83
you could rent a tailpipe expander from autozone to widen the openings just enough to slip on. not sure of the cost but that and a 3/8s rachet is what ya need and when put the clamps use an impact. if ya don't have one available get it has tight as possible and recheck after a couple of days to see if u can tighten it any more. having a connection come loose after a bump and your miles from a store sucks.
Jeep_Runner_83 is offline
post #5 of 8 Old 03-10-2011, 09:16 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
oooooh Harbor Freight sells those cheap also
dukie564 is offline
post #6 of 8 Old 03-10-2011, 09:42 AM Thread Starter
t3553r
hmm sounds like the coupler / pipe expander is my best bet...as far as what pipes should be bigger I assume it's as follows:
Muffler should slide OVER the cat, tailpipe should slide OVER the muffler?
t3553r is offline
post #7 of 8 Old 03-10-2011, 09:48 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
righto
dukie564 is offline
post #8 of 8 Old 03-12-2011, 12:33 PM Thread Starter
t3553r
thanks worked like a charm...for anyone wondering what couplers to get for the parts listed above its 2" - 2 1/8"
t3553r is offline
Replacing front cv joints on 1996 Cherokee Homaler XJ Cherokee Technical Forum 5 09-08-2009 08:07 AM
replacing front bumper 1996 cherokee classic sgilbert83 XJ Cherokee Technical Forum 6 09-02-2008 06:52 PM
Replacing exhaust Duck Vader XJ Cherokee Technical Forum 5 08-31-2007 12:18 PM
Difficulty of replacing exhaust? insurrection151 XJ Cherokee Technical Forum 12 06-06-2007 02:23 PM
1996 Jeep Cherokee Sport recommend exhaust jeffsjeep XJ Cherokee Technical Forum 4 06-19-2002 09:28 PM
