1996 Jeep Grand Cherokee Laredo V8 5.2 AWD Over heating while Idle - JeepForum.com
post #1 of 3 Old 09-02-2011, 01:52 PM Thread Starter
TonyJeep
Hi, My 96 Laredo V8 5.2 150k is over heating while idle. I'v checked all the hoses ,no leaks from the water pump and the fan seems to be working fine. I'v changed the thermostat on it but when I started the Jeep up and waited for the temp to rise so I could make sure the stat worked properly the temp gauge dramatically dropped back to 100 from 210. I turned the Jeep off, when I tried to start it again it wouldnt turn over. I actually had to take the thermostat out for the Jeep to turn over again. Any idea's on what could be the issue. Im at a loss and I really love my Jeep. Im running it at the moment without a thermostat and its still over heating. I need to sit idle for long amounts of times in my Mobile Jeep Office for work so this is no good and I would like to keep the crazy mechanic fee's out of this. "ANY" help would be great.
Thanks
TonyJeep is offline
post #2 of 3 Old 09-02-2011, 04:56 PM
xjwags8789
I'm not sure why the jeep wouldn't turn over with the thermostat. Have you checked to see if the water pump is pumping. If it is try to examine your engine block and see if the head gasket may be leaking
xjwags
xjwags8789 is offline
post #3 of 3 Old 09-02-2011, 05:07 PM
rugsucka
-you're in the wrong forum, but there are other considerations such as water pump impeller being worn to nothing, a plugged up radiator, faulty temperature sensor. I'm sure the Grand Cherokee forum can give you more specifics - we're all about the 4.oL here.
you need to stop driving your vehicle overheating like that. Mobile office or not, if you crack the block, warp the head, or blow a head gasket you will become a static location with a serious repair ahead of you.
rugsucka is offline
idle , overheating
1996 Jeep Grand Cherokee Limited Transmission Problem mbg-jeep ZJ Grand Cherokee Forum 7 03-04-2014 05:54 AM
Replace Headliner 97 Jeep Grand Cherokee Laredo Jesy420 XJ/MJ Cherokee Non-Technical Forum 2 05-03-2011 11:49 AM
1993 Jeep Grand Cherokee Laredo 6 Cylinder 4.0 E-Racer XJ Cherokee Technical Forum 16 03-29-2011 04:39 AM
95 jeep grand cherokee laredo cburgin XJ/MJ Cherokee Non-Technical Forum 4 07-27-2010 05:34 PM
1996 Jeep Cherokee High Idle msl4 XJ Cherokee Technical Forum 1 05-15-2009 04:21 PM
