1996 Jeep Cherokee Starter problem - JeepForum.com
post #1 of 13 Old 11-12-2006, 04:32 PM Thread Starter
Duff750
Got a 1996 Jeep Cherokee inline 6...Girlfriend's vehicle, out of nowhere the starter just quit workin. I don't know a whole hell of a lot about workin on 4 wheeled vehicles, so I thought I'd come here in search of answers. Turn the key and get nothin...can't hear the relay can't hear the solenoid clickin', and of course the starter is not flyin. Where might I begin lookin' for the problem?
Duff750 is offline
post #2 of 13 Old 11-12-2006, 04:43 PM Thread Starter
Duff750
Need to get this fixed ASAP...any input would be greatly appreciated
Duff750 is offline
post #3 of 13 Old 11-12-2006, 04:51 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Be patient. Sometimes it takes a couple of hours for someone to reply. It could be a bad starter itself. When mine went bad, it wouldnt click either. It also could be your Neutral Safety Switch. Its job is to disable the starter when the shifter is in reverse or drive. When it goes bad, it wont let it start in any gear. I dont know how to clean it, or replace it though. Try tapping on the starter with a mallett, it could be stuck. Good Luck.
88XJSport is offline
post #4 of 13 Old 11-12-2006, 04:54 PM
XJ4oh
1997 XJ Cherokee
First off check the easy stuff. Make sure the battery terminals arent corroded and that they are tight, if thats not the case tap the starter with a mallet or hammer and see if that will cause it to crank over. Also try starting in nuteral to see if its the NSS like stated above.
'97 XJ... 4.0 4x4 AW4. 2" budget boost w/t-case drop.
31x10.5 Cooper Discoverer ST's on 15x7 Cragar Soft 8's.
Intake, Ported TB, TB spacer, Super 40 Flowmaster.
Baja Aux. Lighting.
Green Jeep Club #185, Nowhere to Wheel Jeep Club member #1
'04 WJ - Columbia Edition - 4.7HO 2WD
XJ4oh is offline
post #5 of 13 Old 11-12-2006, 04:54 PM Thread Starter
Duff750
Doesn't have a neutral safety switch. That year can be started without the clutch down and in gear if you wanted to. If it were the starter itself, it would most likely be a siezed pulley or somethin' if the solenoid's not clickin'...in which case I would think the lights would be dimming when you hit the starter, but that's not the case. Appreciate the feedback though
Duff750 is offline
post #6 of 13 Old 11-12-2006, 04:59 PM
88XJSport
88XJSport's Avatar
1988 XJ Cherokee
Yes i think if it was a siezed starter, the lighs would dim. Maybe ignition switch? Not sure on that though You are right there is no NSS on a manual, other than that, Im stumped.
post #7 of 13 Old 11-12-2006, 05:02 PM Thread Starter
Duff750
Hmm..just had a thought, any idea if there's a starter relay fuse in the interior fuse box?
Duff750 is offline
post #8 of 13 Old 11-12-2006, 05:56 PM Thread Starter
Duff750
Found and checked all the fuses and relays...all seems to be well with that. So I'm guessing solenoid for sure...but a minor problem, as I said I'm not too savvy on 4-wheeled vehicles...so where might one go about finding the solenoid and how do I test it?
Duff750 is offline
post #9 of 13 Old 11-12-2006, 07:36 PM
jeepinarkansas
1982 CJ8
take it to autozone and they will test it for free.
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #10 of 13 Old 11-12-2006, 08:47 PM
kencaz
How did you check the relay? Do you hear it when you turn the key to "Start" Check for 12V on either pin #85 or #86 (one is ground), with the key in the "Start" position...
Also you can jump pins #30 & #87 in the relay socket and it should turn the starter over reguardless of key position. If it starts then your relay, (or posibly ignitions switch) is bad.
KC
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #11 of 13 Old 11-13-2006, 07:01 AM
Herdfan
Yes, they do.
2007 XK Stock (for now)
1996 XJ Stock, K&N drop in, Tach Gauge Swap
Herdfan is offline
post #12 of 13 Old 11-13-2006, 07:41 AM
anony91xj
First, test the battery. Not with a voltmeter, do a proper test with a tester that can put a load on the battey and check the CCA's. A car battery can put out 12v but not enough amps to turn the engine over. Also, make sure the connections there are good and tight.
If that's OK, have a friend hold the key in the START position while you check for power at the starter trigger wire with a voltmeter or test light. If you've got power there, replace the starter.
1998 VW GTI 2.0
anony91xj is offline
post #13 of 13 Old 11-13-2006, 10:55 AM Thread Starter
Duff750
Talkin' out of my language man lol. Like I said above, TOTAL newb at this kinda thing. Give me a bike and I'll fix it, give me a jeep and I'll stand there and stare at it.
Duff750 is offline
Starter - 1996 Cherokee Sport rdm7938 XJ Cherokee Technical Forum 27 02-11-2010 05:29 AM
1996 Cherokee idle surge/die problem... Julian1221 XJ Cherokee Technical Forum 8 10-08-2009 01:46 PM
1996 jeep cherokee no tachometer jkylshark XJ Cherokee Technical Forum 7 06-05-2009 01:42 AM
Ignition Problem I think with 1996 Cherokee hritz77 XJ Cherokee Technical Forum 5 06-21-2008 01:11 PM
New to the board - have 1996 Jeep and a Problem... EzPcConcepts XJ Cherokee Technical Forum 9 11-18-2007 07:02 PM
