1996 Jeep Cherokee Sport - JeepForum.com
post #1 of 12 Old 02-09-2010, 06:49 AM Thread Starter
GravyTrain7
Hello everyone. Just picked up a 1996 Jeep Cherokee Sport. My first
Jeep. Picked it up for $4000 with 80,000 miles. Everything looks to
be in great condition. Great ride. I am turning it in soon as I found that
there is a recall on the ECM / Cat Converter. I have a lil rattle in the
converter, so I'm gonna get that taken care of. What are some things
I should know about my Jeep? Look forward to chatting with you all
and getting more familiar with my new addition.
Also, I'm an idiot. I have no idea what an XJ is or if I have one.
GravyTrain7 is offline
post #2 of 12 Old 02-09-2010, 07:02 AM
DYNOMAN
1989 MJ Comanche
Good Luck With Your Jeep....................
DYNOMAN is offline
post #3 of 12 Old 02-09-2010, 07:03 AM
FletchXJ
XJ=Cherokee so you do have one, . And congrats on the Jeep!
FletchXJ is offline
post #4 of 12 Old 02-09-2010, 07:04 AM
Bane7962
Im jealous man.
I bought mine with 150,000
That XJ will last you for a good long while
Bane7962 is offline
post #5 of 12 Old 02-09-2010, 07:07 AM Thread Starter
GravyTrain7
So all cherokee's are XJ's? Thanks on the congrats!
post #6 of 12 Old 02-09-2010, 07:09 AM Thread Starter
GravyTrain7
Originally Posted by Bane7962 View Post
Im jealous man.
I sure hope so. I've had it a week and love it. Although, I have to
get the converter recall done. Also, the check engine light came
on a couple days ago. Was an O2 sensor. The dealer replaced it free
of charge even though it wasn't "a power train" issue.
Thanks for the reply!
post #7 of 12 Old 02-09-2010, 08:35 AM Thread Starter
GravyTrain7
Any advice? Its snowing here...dying to go driving.
post #8 of 12 Old 02-09-2010, 08:42 AM
Rtbeebe
1997 XJ Cherokee
Gravy,
I bought mine with 70,000 almost 9 years ago here in Radcliff. Its going on 200K and still rippin. My son actually has taken over as the primary but I still maintain. You should give it a good once over. I found the Diffs were almost empty on mine when I bought it. Other thana good check, be prepared to repair as needed. Things will go wrong. The good thing is that alot of XJs were turned in during the cash for clunkers so there are alot of junkyard heaps with good used parts. Find one that matches your jeep and make sure they don't crush it.
Good luck
97 Cherokee sport 4WD w/ 4.0
Rtbeebe is offline
post #9 of 12 Old 02-09-2010, 08:42 AM
tjwalker
It's the crank sensor!
tjwalker's Avatar
Originally Posted by GravyTrain7 View Post
What are some things I should know about my Jeep?
Unless you have believable maintenance records showing changes recently, it's a good idea to change ALL fluids. They're the lifeblood of your vehicle and changing them now establishes an honest baseline for future maintenance.
Coolant and fresh stat, oil and filter, transmission fluid, transfer case, both differentials and if you're ambitious....brake and power steering fluid.
Keep your tuneup hardware fresh (plugs,wires,cap,rotor,air filter,fuel filter)
Enjoy your 96...
99 Cherokee, 4.0 AW4, NP242
Past Jeeps: 49 Willys, 81 Scrambler, 88 Comanche
Without "data", all you have is an opinion!
tjwalker is offline
post #10 of 12 Old 02-09-2010, 08:53 AM Thread Starter
GravyTrain7
Originally Posted by Rtbeebe View Post
Gravy,
Good luck
Enjoy your 96...
Thanks guys. I only have the records of the changes the dealer did prior
to putting the vehicle on the lot.
One thing I am having trouble with is the lock on the driver side door. It
won't turn half the time. Have to go to the passenger side to get in. Of
course this didn't happen when I purchased the vehicle. Thinking of
having the Jeep Dealer check it our when I turn in for the recall. Hoping
that won't be much of a charge to fix or replace. Not exactly a mechanic
myself.
post #11 of 12 Old 02-09-2010, 01:36 PM
Lupitaboy
Gravytrain....running to the dealer over a lock issue could go a couple different ways. 1. The dealer could have his mechanic graphite the keyhole while manipulating things or 2. Schedule shop time at $85 per to dismantle the doors interior and fix or replace parts, if available, at the current rate of exchange for gold bullion. Don't expect freebie or cheapie repairs at any dealership for a 14 yr old discontinued model of any automotive line.
So do your searching here and at NAXJA stock forum for tips and pointers to save you time and money. The majority of participants here do their own repairs, if possible, and usually will be the last types to recommend sending you to the dealer for such a minor repair item. You bought a used XJ. Get a used FSM manual. Then get used to figuring out the simple fixes while learning more about your purchase. For many of us here, our XJ's are pretty much our main hobby. Other than working to support that hobby.
96 w/ 5spd, 4.10s w/ lsd, Bastard Packs, armor/ rack, BFGs & JK Blacks
Lupitaboy is offline
post #12 of 12 Old 03-13-2017, 06:11 PM
GravITrain7
Unhappy 96 Jeep XJ + High Tide = ..?
Hello Jeepsters,
She got a bit too damp.
my ECU wasn't sealed:/
I have dropped both trans and oil pan
ran hot water thru
put new PCM in
connected to TJ via jumper cables
Haven't tried to crank
headlights work
check engine and GEN lights light up
Fuse box under steering wheel began to smoke so i disconnected power supply.
Any suggestions y'all may have I would love to hear
Thanks
ST
GravITrain7 is offline
Starter - 1996 Cherokee Sport rdm7938 XJ Cherokee Technical Forum 27 02-11-2010 05:29 AM
1996 Jeep Cherokee Sport - air not blowing from the front vents ddvmd3 XJ Cherokee Technical Forum 0 04-27-2009 09:44 PM
Need a 1996 Jeep Cherokee Sport 6cyl 4.0L fuse box explaination ErickaS XJ Cherokee Technical Forum 3 03-08-2009 10:32 PM
Need Help 1996 Cherokee Sport nmblkmtn1 XJ Cherokee Technical Forum 7 02-11-2007 06:04 PM
1996 Jeep Cherokee Sport recommend exhaust jeffsjeep XJ Cherokee Technical Forum 4 06-19-2002 09:28 PM
