1996 Jeep Cherokee High Idle - JeepForum.com
post #1 of 2 Old 05-14-2009, 07:08 AM Thread Starter
msl4
Got a 1996 Jeep Cherokee Country that is idling between 3,000 and 4,000 RPM. This thing is multiport fuel injection. How do I get the Idle back down to what it is suppose to be?
msl4 is offline
post #2 of 2 Old 05-15-2009, 04:21 PM
viper719
first things first, high idle can be caused by a bunch of problems. First, check all the vacuum lines, being a 96 (same year as mine) the plastic lines are starting to get old and brittle, might have cracked one. Also, sometimes pulling the battery out and letting it reset it self for about 10 minutes before re-installing might help. Check your IAC and TPS as well, the IAC can be removed with a t10 or t15 torx drive, and cleaned using a small toothbrush and throttle body cleaner. These things get gummed up after a while, and need either replacmenet or a good GENTLE cleaning.
Some obstacles can not be moved, those you have to either- 1)go around, 2)go over 3)go under, or 4) my personal favorite, blow the heck up and go through the rubble!
viper719 is offline
1996 Cherokee idle surge/die problem... Julian1221 XJ Cherokee Technical Forum 8 10-08-2009 02:46 PM
Strange Problem with my 2000 Jeep Cherokee-Unintended Acceleration, High Idle Hackworth75 XJ Cherokee Technical Forum 11 01-19-2008 03:36 PM
88-91 Jeep Cherokee Intermittent High Idle LeeMan1976 XJ Cherokee Technical Forum 9 07-29-2006 06:26 PM
1989 Cherokee High idle flanker_13 XJ Cherokee Technical Forum 3 12-09-2005 09:07 AM
87 cherokee 4.0 high idle el jasto XJ Cherokee Technical Forum 3 11-20-2001 02:20 PM
