Quantcast 1996 Jeep Cherokee Country, Check engine light on, Sputtering/rumbling. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 1996 Jeep Cherokee Country, Check engine light on, Sputtering/rumbling.
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!Black Magic Brakes, KOH Weekend Special!!Brand new! XJ Rear DIY Bumper from JcrOffroad!
Old 06-28-2004, 12:16 PM   #1
CapaJeep
I have a 1996 Jeep Cherokee Country 6cyl, 4.0, 4x4, 115,000miles. The check engine light is on. It is sputtering/rumbling (sounds like its going to stall out, but then corrects itself, or I can generally correct it by revving it up in neutral) mostly at low speeds, often when stopped at a red light or stop sign, etc... This is accompanied by a general slight loss of power.
Steps I have taken:
1. New Spark plugs
2. New Wires
3. Cleaned out the throttle body and air intake
4. New Air filter
5. New Fuel filter
6. Fuel system cleaner (add in gas tank).
7. On, off, ignition key test. It is difficult to read. I get what appears to be a 33 followed by a 55 (end of codes). According to the following websites, code 33 is “An open or shorted condition detected in the A/C clutch relay circuit.” Again that is if I’m reading the above codes correctly. I should add, I’m not running the A/C, heat, fan, etc. when the problem occurs. Does this code make sense in my situation? If so, how do I go about correcting it? If not, any suggestions?
http://www.jedi.com/obiwan/jeep/dtc.html
http://go.jeep-xj.info/HowtoECUcodes.htm
8. I checked all auto parts stores in my area, none of them either check codes or have the scanner to loan for my vehicle.
Any suggestions on what the problem might be?
Thanks for your help,
CapaJeep
CapaJeep is offline   Reply With Quote
Old 06-28-2004, 01:28 PM   #2
Jeep Cherokee
We're had that same prob in one of our delivery trucks.. So far we've replaced the EGR valve, fuel pump/sender, fuel filter.. plugs/wires/cap/rotor, o2 sensors.. just got an ECU in today.. now we are going to try that. Do you have an autozone in your area? they usually scan the cars for you.. if not then your best bet is to hit up the dealer or a garage and pay the 60 bucks.
Red Jeep Club Member #16
Become a fan of the Jeep Cherokee XJ Facebook Page
Jeep Cherokee is offline   Reply With Quote
Old 06-28-2004, 11:56 PM   #3
CapaJeep
Thanks for the reply. Prior to writing my post, my local Autozone did not have a scanner, however, they did get one in tonight so I’ll try it out tomorrow. Thanks again.
Old 06-29-2004, 11:29 AM   #4
DirtyWigeon
I had the same issue. After checking the computer Cyl #3 was miss fireing. I did a fuel injection service ( 3 part ) and everything runs smoth as sink now.
I got 5$ on Dirty or failing fuel injector.
DirtyWigeon is offline   Reply With Quote
Old 06-29-2004, 12:49 PM   #5
CapaJeep
DirtyWigeon,
I hope your wrong. We'll find out today or tomorrow. I was able to get a scanner. I used the OBD-II Auto Scanner. The code is PO132 - O2 Sensor Circuit High Voltage - Bank 1 Sensor 1 (Sensor 1 is located upstream of the catalytic converter).
Any tips in replacing it post here or please see:
http://www.jeepforum.com/forum/f11/replacing-o2-sensor-90981/#post604132
Thanks,
CapaJeep
Old 06-30-2004, 10:01 AM   #6
CapaJeep
Well, it was the O2 sensor. It was pretty easy to change and it's running good now. Thanks for the replies.
Old 06-30-2004, 11:13 AM   #7
DirtyWigeon
good to hear.
Old 06-21-2011, 01:15 PM   #8
Whiskey326
is there more then one? Did you replace the one near the oil pan?
Like this? thanks
Whiskey326 is offline   Reply With Quote
Glock Forum
