1996 Cherokee wont start - JeepForum.com
post #1 of 12 Old 01-23-2007, 02:05 PM Thread Starter
92Heep
1992 XJ Cherokee
Ok, i tried using the search function. im a Noob to these forums so hi all! ive been around jeeps for years, we are on our 7th cherokee. We are having a no start issue - when you turn the key we get nothing.. the started doesnt make a noise - but we hear the relays clicking. If we turn the key to the on position, using a screwdriver on the starter crossing the positive and negative poles i can get it to start right up. Could this be a neutral saftey problem? is there a way i can just jump it? Its a 1996 Cherokee Sport 4.0l. Thanks in advance for your input!
92Heep is offline
post #2 of 12 Old 01-23-2007, 02:21 PM
xjunkie8796
Either your starter is junk or it may be your NSS put it in neutral and try it. My nss is going slowly. But anyways Welcome
xjunkie8796 is offline
post #3 of 12 Old 01-23-2007, 02:38 PM Thread Starter
92Heep
1992 XJ Cherokee
thanks for the reply and welcome! i know its not the starter.. i can jump the posts with a screwdriver and it starts right up. i also had the starter tested i guess its the neutral safty? could i bypass it?
92Heep is offline
post #4 of 12 Old 01-23-2007, 04:23 PM
red96jeep
same thing just happned one mine.check the ignition switch.
1996 jeep cherokee se 2 door
5 inch lift
rear ended= totaled
Rocky Mountain Edition Club member #4
project vehicle
new 2002 jetta 1.8t DD
red96jeep is offline
post #5 of 12 Old 01-23-2007, 04:32 PM
joshs1ofakindxj
the NSS wouldnt let the relays on the starter click.
joshs1ofakindxj is offline
post #6 of 12 Old 01-23-2007, 04:52 PM
kencaz
I don't think it's an NSS problem. Pull the starter relay, get a piece of wire and jump the relay socket #30 and #87. If the starter turns over then the relay is bad. If it does not turn over check the 40A fuse for the starter circuit.
KC
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #7 of 12 Old 01-23-2007, 05:23 PM Thread Starter
92Heep
1992 XJ Cherokee
how would i check the ignition switch? also the relays im referring to are the ones in the black box right under the hood. Ill check the 40A fuse to see if that is the problem. thanks for your replies ill let you know the outcome!
92Heep is offline
post #8 of 12 Old 01-24-2007, 09:47 AM Thread Starter
92Heep
1992 XJ Cherokee
bump for not knowing how to check ignition switch
92Heep is offline
post #9 of 12 Old 01-25-2007, 08:23 AM
XJJeep96
Happens to mine to, sometimes it does it sometimes it doesnt, but i just put it in nuetral to start it.
XJJeep96 is offline
post #10 of 12 Old 01-25-2007, 11:31 AM
xj-xile
xj-xile's Avatar
I had this problem the other day. Putting it in neutral didn't help. All I did was take the cables off the starter, clean the contacts, and bolt the cables back on. No problems since.
xj-xile is offline
post #11 of 12 Old 01-25-2007, 12:03 PM Thread Starter
92Heep
1992 XJ Cherokee
interesting, thanks for the reply ill try that.. also has anyone ever heard of 96+ cherokees needing the Brake to be on in order to start? like you have to press the brake while starting to make it start? i dont know where the heck my dad ever heard that bs from?
92Heep is offline
post #12 of 12 Old 12-09-2009, 12:21 PM
thakoolaidkid
Ok, so did a search and I wound up here. I had almost the same problem. Went to pump gas, left the lights on, went to start the car and nothing. No click, nothing. The dash lights all turn on just fine. I hooked it to a battery charger and nothing happened, no click, no noise.
The mechanic comes out cause Im blocking the fuel lane and he takes off the cover of the relays and a relay switch, nothing. He takes a piece of wire and connects it to the two prongs of the starter relay and nothing. So we search around, wait five minutes. And I try one last time and it fires up.
He said he doesn't believe the starter is bad, maybe a dead spot (wtf is a dead spot?) and he thinks it may be the ignition. I drove it back to work for the time being but I'm dreading the end of the day. Any ideas on how I can get it to start right up? Think it may be my NSS and not something more costly such as a starter or whole new ignition? If it was my NSS would I still hear clicking from the starter?
'96 ZJ: Sold.
'94 XJ: Sold for scrap.
'01 TJ: Back in a Jeep after 3 years!
thakoolaidkid is offline
1996 jeep cherokee WONT START mmitche6 XJ Cherokee Technical Forum 1 12-10-2009 05:33 AM
1996 XJ, cranks but wont start, details in here! funnynyck XJ Cherokee Technical Forum 16 08-03-2009 10:34 AM
Angry Cherokee Wont Behave..start and die every 30 min! wont start then run 30 later! bcameron1974 XJ Cherokee Technical Forum 10 06-05-2009 01:22 PM
1996 cherokee 4.0 no start montemann XJ Cherokee Technical Forum 3 04-15-2005 03:21 PM
1996 Cherokee won't start....no spark jms493 XJ Cherokee Technical Forum 4 11-29-2003 08:09 PM
