1996 Cherokee won't start - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > 1996 Cherokee won't start
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!The Original 3/8" Ruffstuff Diff Cover!
Unread 08-30-2011, 11:57 AM   #1
amycakes
1996 FSJ Cherokee
I have a 1996 Cherokee 4 cylinder. Changed the head gasket, spark plugs, spark plug wires, and ignition coil. Cleaned distributor cap. Still not getting any spark. Help!
amycakes is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 05:35 PM   #2
XJ2JK
Try checking your ground wires. Clean them off real good.
XJ2JK is offline   Reply With Quote Quick reply to this message
Unread 08-30-2011, 06:05 PM   #3
mtwask01
1995 XJ Cherokee
If it cranks and cranks but won't start, I would check the crankshaft position sensor (CPS or CKP). It is the usual suspect when dealing with the engine turning over but not firing and no spark. CJ7-Tim has loads of information on testing and replacing this sensor. Read the first post on this thread for his advice:
http://www.jeepforum.com/forum/f11/x...ensor-1167378/
mtwask01 is offline   Reply With Quote Quick reply to this message
