1996 Cherokee won't start - JeepForum.com
post #1 of 3 Old 08-30-2011, 12:57 PM Thread Starter
amycakes
1996 FSJ Cherokee
I have a 1996 Cherokee 4 cylinder. Changed the head gasket, spark plugs, spark plug wires, and ignition coil. Cleaned distributor cap. Still not getting any spark. Help!
amycakes is offline
post #2 of 3 Old 08-30-2011, 06:35 PM
XJ2JK
Try checking your ground wires. Clean them off real good.
XJ2JK is offline
post #3 of 3 Old 08-30-2011, 07:05 PM
mtwask01
1995 XJ Cherokee
If it cranks and cranks but won't start, I would check the crankshaft position sensor (CPS or CKP). It is the usual suspect when dealing with the engine turning over but not firing and no spark. CJ7-Tim has loads of information on testing and replacing this sensor. Read the first post on this thread for his advice:
http://www.jeepforum.com/forum/f11/x...ensor-1167378/
mtwask01 is offline
1996 Cherokee, won't even try to start tiber XJ Cherokee Technical Forum 9 11-23-2010 05:56 PM
1996 cherokee wont start 1996jeepxj XJ Cherokee Technical Forum 12 06-16-2010 09:53 PM
1996 Cherokee wont start 92Heep XJ Cherokee Technical Forum 11 12-09-2009 01:21 PM
1996 cherokee 4.0 no start montemann XJ Cherokee Technical Forum 3 04-15-2005 04:21 PM
1996 Cherokee won't start....no spark jms493 XJ Cherokee Technical Forum 4 11-29-2003 09:09 PM
