1996 Cherokee Sport 4.0 6cyl lift suggestions - JeepForum.com
post #1 of 6 Old 09-27-2006, 10:43 AM Thread Starter
lukemodrow
I have a 1996 Cherokee Sport 4.0 6cyl. Everything on it is pretty much stock. I would like to throw a 4.5"- 5" lift on it, but I have no idea where to start. I'm fairly new to the Jeep world, so anyone that can suggest anything would help.
Questions:
1. What is the rule of thumb when you install a lift?... for example, if you install a 4.5" you need to also replace ___. etc....
2. What can I expect to pay said and done?
3. What are some unexpecteds that people have run into in the past that would be nice to know?
4. I am very mechanically inclined, but I haven't done much automotive work. This looks to be a fairly big job, so would you suggest I do it myself or get it installed for me? If getting it installed for me is the route to go, what should I expect to spend?
Like I said before, anything helps... Thanks again to anyone who posts answers for a rookie in need...
Later,
Luke
lukemodrow is offline
post #2 of 6 Old 09-27-2006, 10:51 AM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Mall crawler or off road rig?
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 6 Old 09-27-2006, 11:03 AM Thread Starter
lukemodrow
Mall Crawler?... if you mean grocery getter, yes. It is 4x4, but I wouldn't call it a off road rig yet. That's what the main reason for the post is, to make it a decent off road rig. Any suggestions on lift projects you've done would be great. Thanks again.
post #4 of 6 Old 09-27-2006, 11:04 AM
gregmondro
gregmondro's Avatar
SYE or T-Case drop (SYE is the preferred one, you can also do a Hack and Tap which i'd recommend if you want to save some cash).
Adjustable Trackbar (may or may not come with lift depending on what/where you buy from)
Proper length control arms for your lift (not a problem if you're buying the lift complete)
Regearing if you plan on adding larger tires to compliment the lift
Just a few things to consider.
- NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
gregmondro is offline
post #5 of 6 Old 09-27-2006, 11:32 AM
Matt Gertsch
www.lp.org
Rubicon Express is a good brand and a few of the forum vendors offer discounts to members. You might also want to look into Full Traction and Rock Krawler. It just depends on what you expect the rig to do. Count on spending the money for an SYE and new rear drive shaft as well as a front and rear ring and pinion, plus installation. Once you get around 33s, tire start to get spendy, so count on 5 of those as an expense.
All told, count on something in the neighborhood of $4500+.
post #6 of 6 Old 09-27-2006, 11:39 AM Thread Starter
lukemodrow
Thanks for responding Greg. I appreciate the suggestions!
1996 Jeep Cherokee Sport GravyTrain7 XJ Cherokee Technical Forum 11 03-13-2017 06:11 PM
Starter - 1996 Cherokee Sport rdm7938 XJ Cherokee Technical Forum 27 02-11-2010 05:29 AM
Need a 1996 Jeep Cherokee Sport 6cyl 4.0L fuse box explaination ErickaS XJ Cherokee Technical Forum 3 03-08-2009 10:32 PM
1998 Jeep Cherokee Sport Utility SE 4D 4x4 6cyl searcherrr XJ Cherokee Technical Forum 16 06-14-2008 01:34 AM
Need Help 1996 Cherokee Sport nmblkmtn1 XJ Cherokee Technical Forum 7 02-11-2007 06:04 PM
