1996 Cherokee Front Brake question? - JeepForum.com
post #1 of 3 Old 06-25-2013, 10:17 AM Thread Starter
burdman
Hey All,
So I have a rookie brake question; I'm replacing my pads & rotors on my 1996 Cherokee and just read some info on the removal/install and it says that a C-Clamp is needed to compress caliper pistons and remove/install new pads?
I haven't done a brake job myself in about 10-15years, so I didn't even think about this when I bought the new pads/rotors last night and I don't have a C-clamp.
Before I get started, am I going need a C-clamp to do this work or is it possible to do the work without one?
I don't want to start pulling everything off and then realize that I don't have proper tools and then have no way to get to the store.
Appreciate feedback.
Cheers-
Scott
burdman is offline
post #2 of 3 Old 06-25-2013, 11:12 AM
xj-jake
A C-clamp is best because you can apply even pressure to the center of the caliper piston and get it pushed back in evenly. I've used a big adjustable pliers before it worked fine. Worst case scenario you can use a big screwdriver to push it back in by putting the caliper back in place and prying against the rotor.
99 XJ 6.5" IRO Long Arm on 17" Pro Comp 7086 wheels w 33" Tires
xj-jake is offline
post #3 of 3 Old 06-25-2013, 01:11 PM Thread Starter
burdman
Thanks Jake for reply. Yeah, I figured it was best to go grab a c-clamp from the store, since I don't own a good pair of pliers. Also grabbed some brake cleaner and now just need to let it cool down a bit, so I can get at it. Hoping it all goes well.
burdman is offline
