Quantcast 1996 4.0L turns over but wont fire... HELP! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > 1996 4.0L turns over but wont fire... HELP!
Old 06-05-2007, 02:11 PM   #1
BRad704
Nothing to see here...
BRad704's Avatar
My 96 Country was running fine Saturday night, and when I went to leave for work Sunday morning, it would turn over like normal but not fire. So far I have determined the following:
- it is getting airflow
- it is getting fuel
- it wont start on starting fluid, therefore it is not getting spark
- it wont even fire while trying to jump it off from another car
- fuses are all OK
- relays are all OK
I have already replaced the dist cap, rotor button, and ignition coil... NO luck! Has anyone else had these kinds of symptoms? Right now, I'm looking at the distributor switch plate (under the rotorbutton), but its $47 at my shop cost and I dont even know if this could be a problem.
Originally Posted by Jungle Recon
*** this quote has been removed by BRad, in order to maintain the level of maturity that is required in an online forum of one's peers.
BRad704 is offline   Reply With Quote
Old 06-05-2007, 02:26 PM   #2
88XJSport
1988 XJ Cherokee
Since there is no spark, have you tried your Crankshaft Position Sensor??
88XJSport is offline   Reply With Quote
Old 06-05-2007, 03:04 PM   #3
XJdamyankee
My 96 did the same thing. Mine ended up being the wires going into the coil, had a short in them. But def. check your CPS crankshaft position sensor.
96 cherkoee SE I-6 AW-4 np231 dana30/chrys 8.25
Doug Thorley Tri-Y header/magnaflow cat/rustys FM50 exhaust
Kumho KL71's 31x10.5x15 mounted on rock crusher 15x8 w/4.5"BS black D-window
OME 2" lift & shocks, RE super-ride control arms
XJdamyankee is offline   Reply With Quote
Old 06-05-2007, 03:10 PM   #4
BRad704
BRad704's Avatar
i tried a new coil and that didnt fix it, so im waiting on my CPS to get here this afternoon... I've already unbolted the old one, so by the end of the day, I'll be able to give an update on the CPS...
Old 06-05-2007, 05:24 PM   #5
BRad704
BRad704's Avatar
yep... it was the CPS...
Old 06-05-2007, 05:26 PM   #6
88XJSport
1988 XJ Cherokee
Congrats on getting it fixed! Have Fun
Glock Forum
